Results 1 to 12 of 12
This is a discussion on Zmax within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ok maybe I need more sleep but here we go. I am sure you have all seen the infomericals for ...
    Jun 2002
    Rochester,NY
    Zmax
    Ok maybe I need more sleep but here we go. I am sure you have all seen the infomericals for Zmax. Any one know if that stuff works?http://www.aplustvproducts.com/Automotive/zmax.asp
    Registered User SonicYellowWRX's Avatar
    Aug 2002
    ok. Here is what I know.
    -ZMAX has a lawsuite against them.
    -A friend used it and says it works.
    -The car can last a lifetime without ever touching any additives.
    I wont use the stuff cuz its probably BS and the car has no use for it anyways. RESTORE is a popular product that actually works, but if the car runs better with it then it means you have problems with the engine and its only a temporary solution. MUGEN also released its own oil additive... that I would trust. (for hondas only though) Now if STi released an oil additive, then it'd probably be worth checking out.
    Yes, that is me in my avatar! Kid's don't try this at home.
    CLICKY to view My Extensive Mod List!
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    Marketing spin from their website:
    zMax Power System soaks into metals with its micro lubricating molecules for increased horsepower, reduced fuel consumption, and decreased emissions.
    As somebody with an engineering degree in metallurgy, this first paragraph alone would steer me away from ever using this product.
    -Pace
    Registered User djrez4's Avatar
    Colorado
    -Pace
    why? please explain
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Law for Small Businesses - The D. J. Marcus Law Firm
    Sep 2001
    They claim that the 'system soaks into metals'. I hope they are trying to communicate that it simply coats engine components and does a good job of moving into the interfaces between distinct components to form a lubricating film. If any of the metallics used in our engines have a surface porosity that will permit molecular inclusion of lubricating fluids, then I would say that the relative merit of engine additives such as this is the least of our concerns.
    Next time your oil level is low, just remember that it's because it got 'soaked up' by your [insert metallic component of choice here].
    Just my 2c.
    -Pace
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Yeah, their commercial imples that is "soaks" is at a molecular level - that is, the zmax molecules are smaller than the spaces between the metal molecules. You're right, probably a bunch of bovine doo-doo.
    Remember that the big oil companies (and even the smaller niche ones like Redline and Amsoil) invest millions and even billions in R&D. These companies know how to properly lubricate a motor. Thes companies with their infomercials may be on to something, but likely they're selling snake oil!
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Royal Oak, MI
    Just my 2c.
    -Pace
    Yeah. I think that oil soak is the reason why I have to keep adding a quart of oil a month to my old Chevy pick up. Now if I can just figure out what's causing that dark spot on my driveway.....
    Alin
    Registered User SACTOWNREXMAN's Avatar
    Aug 2001
    Elk Grove, CA USA
    I bought it and ran it for the hell of it in the WRX. No change. I would never do it again. But, my reasoning was that if the FAA aproves it, it has to be some good ish, because the are very restrictive on what you can run in an aircraft engine.
    Andy
    Royal Oak, MI
    I believe the FAA approved Linkite(sp?) which Zmax lists as one of their ingredients.
    Alin
    Aug 2001
    Elk Grove, CA USA
    Yes, that is the key ingredient. The Linkyte (?spelling) soaks into the metal!
    Andy
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    They are also under investigation by the FTC. They claim all the Zmax additives are mineral oil mixed with a dye to give it color.
    http://www.ftc.gov/opa/2001/02/zmax1.htm
    Thanks,
    Ali
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    Alin
    LOL
