Results 1 to 15 of 15
This is a discussion on Maintenance, Service FAQ & Factory Recommended Maintenance Schedule within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This FAQ is meant as a supplement to your owner's manual. Use the search feature as many general questions has ...
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Fluids
    Engine Oil
    2.0L Turbo
    Maximum Capacity: 4.8 quarts
    Minimum Capacity: 3.7 quarts (lower end of the dipstick)
    Oil Type: 5W-30 (preferred) meeting at minimum API SJ or 10W-30/40 (-4 F or hotter)
    In desert areas (very hot temperatures) or other heavy duty applications:
    SAE 30, SAE 50, 10W-50, 20W-40 or 20W-50
    2.5L Turbo
    5w30 GF-4 API SM Energy conserving
    Transmission
    Manual
    Type: GL-5
    Weight:
    75W-90 (all temperatures)
    80W (86 F and colder)
    85W (-22 F and hotter)
    90 (32 F and hotter)
    Automatic
    Type: DEXRON III*
    Capacity: 9.8 quarts
    Differential
    Type: GL-5
    Rear
    Capacity: 0.8 quarts
    Weight:
    Front (Automatic Transmission)
    Capacity: 1.2 to 1.4 quarts
    Weight:
    80W-90 (all temperatures)
    Brakes
    Type: DOT3 (recommended) or DOT4 (alternative)
    Power Steering
    Type: DEXRON III
    Capacity: 0.7 quarts
    Coolant
    Type: Subaru 00016218
    Capacity: 8.0 quarts (MT)/ 8.1 quarts (AT)
    Clutch
    *DEXRON fluids are downward compatible, ie. DEXRON IV is suitable for DEXRON III
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Engine Maintenance
    Air Filter (stock replacement)
    Stock
    Subaru OEM Engine Air Filter Impreza (short)
    AA020
    Reusable
    AFE
    Pro Dry S (no oiling reusable)
    31-10010
    Normal oil type
    30-10010
    K&N
    Flat oil type
    33-2232
    Green Filters
    flat oil type
    #2019
    Spark Plugs
    Type: NGK PFR6G
    Gap: 0.028 to 0.031 inches
    Torque: 15.19 ft-lb
    Oil Filter and Drain plug
    Drain Plug Torque: 33 ft-lb (always replace gasket)
    Oil Filter Part Number:
    Timing Belt
    [url=http://www.ravensblade-impreza.com/techdocs/pdf/engine/dohctbelt.pdf]Overview of Timing Belt Change (right click--save as)
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Brakes
    Pads
    Rotors
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Bulbs
    Note: numbers in parantheses refer to Sylvania Part Numbers
    Front
    2002 to 2003
    Headlight: 9007
    Turn Signal: P21W (1156)
    Parking Light: W5W (168)
    Side Marker Light: W5W (168)
    Fog Light: H3
    2004 and up
    Low Beam: H1 (D2R for STi)
    High Beam: 9005
    Turn Signal: W21W (7440)
    Parking Light/Side Marker: W5W (168) however, hard to find in amber (194NA) easily found
    Fog light: H3
    Rear
    Sedan
    Tail/Stop: W21/5W (7443)
    Tail: (7443)
    Stop: W21W (7440)
    Turn Signal: WY21W (no sylvania part number, but 7440 amber)
    Back-up: W21W (7440)
    3rd brake light: (921)
    Wagon
    Turn Signal: WY21W
    Interior
    Map: W5W (168)
    Ashtray: (74)
    Dome Light: (DE3175) 31mm long by 10mm dia
    Trunk: (912)
    Nov 2006
    Richmond, Va
    Great info.
    Also want to itterate that the owners manual is just the basic maintenance guidlines, not the only one.
    http://svt4u2try.com | Myspace | Photos
    97 Cobra, 98 Z/28 hardtop
    Registered User El Vocho's Avatar
    Dec 2006
    México
    Really this is a great Post, Thank You Friends.
    It´s complete info
    07´STi Limited Edition 753/800 UGM
    "Very Rare species in México"
    ECU Tunned by COBB S II, Brembo Cross Drilled R, Zero Sports Brake Lines, Zero Sports Brake Pads, K&N Filter, PIAA Bulbs, FIAMM Air Horn, STI Radiator Cap 1.3Kp, MOTUL Oil, Cat-Back Magnaflow, STP Battery H, EIBACH Springs, LaMoo Turbo Boost G, 3M Care Products, COBB Down Pipe SS 3", COBB Sway Bars, STI trailing Link, Michelin Wiper B, STI Valve.
    Nov 2005
    Central Florida
    Part # for 5gal drum of subaru oem mtf and diff fluid.
    k00323aa093
    hopes this helps someone
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Moderator Donkey's Avatar
    Da boonies
    Suprised the fuel rail TSB isn't included in the TSB/Recall section.
    http://forums.nasioc.com/forums/show...08&postcount=8
    2002 FORESTER S
    1998 FORESTER S
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Updated some info. If you have part numbers lemme know and Ill add them above.
    Mar 2008
    Quote Originally Posted by 06wrx4me View Post
    http://cgi.ebay.com/SUBARU-WRX-STI-P...QQcmdZViewItem
    has enyone tried this pod. thanks for any info
    Registered User dchoi23's Avatar
    Mar 2009
    SF-Bay Area
    anyone have a service manual in a PDF format that I can download? thanks in advance!
    Aug 2009
    Upstate NY
    Post
    Quote Originally Posted by dchoi23 View Post
    Old thread, I realize...but for anyone looking back at this, you can get any of the service manuals here:
    Home
    Mar 2009
    SF-Bay Area
    Quote Originally Posted by likuidphreon View Post
    Home
    This is a pretty awesome resource thanks!
    May 2007
    behind the wheel
    The maint. schedule link in post #1 is dead. here's a revised link.
    https://www.subaru.com/my-subaru/mai...edule2009.html
    Rogan o_0
    '01 Dodge 2500 CTD 6-holed hand-shaker - 3850# dual disk
    '97 Dodge 3500 CTD DUALLY built Auto - 40psi boosties
