Worried about 2nd and 3rd gear in WRX
Results 1 to 15 of 19
This is a discussion on Worried about 2nd and 3rd gear in WRX within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Guys: I was about to buy a wrx a few weeks ago, but a few concerns have come to my ...
    Jun 2002
    Unhappy Worried about 2nd and 3rd gear in WRX
    Guys: I was about to buy a wrx a few weeks ago, but a few concerns have come to my attn. First I'm worried about the trany! It seems that the problems with 2nd and 3rd gear are not issolated cases, but common problems for may WRX owners. My next concern is the pre catalytic converters that have been breaking up and sending chunks through the turbo. As WRX owners yourselves, I would verymuch appreciate feedback. Thanks for your time!
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Well, maybe better for a different section, but tranny failures have generally been due to abuse, and the pre-cat thing is jsut a fear. I don't think anybody has had one actually come apart even on modded motors.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Registered User Retro's Avatar
    May 2002
    USA, FL
    Don't assume all the tranny problems were due to abuse. The majority is a good probability, but don't assume that they were all due to abuse.
    Registered User thechickencow's Avatar
    Mar 2002
    West Allis, WI
    Your tranny if you buy one now (assuming it will be a '03) will be different and slightly improved if the word on the street is correct. If not, I still think the tranny problem has to do more with the way the person shifts than the actual driving that is done. Its easy to say you rev match every downshift, but if you're banging into 2nd gear hard everytime you start rolling you're going to hurt 2nd gear.
    The pre-cat is IMO a made up problem to justify replacing the uppipe with a catless one. IF it happened I don't think it would happen for a very long time.
    my $.02.
    J
    Aug 2001
    Houston, Texas
    I think first gear will break if you consistently drop the clutch from near redline with low tire pressure/no wheel spin. I have seen the broken gear at the dealer but I think it was an extreme case of abuse. Check out the other car forums like acura and you'll find the same problems and concerns. A good friend of mine worked at acura for years as a service advisor and he saw a lot of street racer guys with GS-Rs and Type Rs coming through the service dept. with stripped gears and such. I certainly wouldn't say the WRX transmission is "glass" but it's not indestructable either. I would guess that most of the transmission problems are related to driver skill or the lack of.
    Regarding the pre-cat in the up-pipe, I was told by one of the techs at cobb tuning that the catalyst is metal and after having the up-pipe replaced and looking down into the old up-pipe, the catalyst sure appears to be made of metal. I think it's highly unlikely that the precat will ever pose a problem. BTW, I didn't throw a CEL until I removed this cat. Prior to this I had the TurboXS turboback exhaust. I'm not sure if the gains were worth it. The PEP mil elim seems to have cured the CEL. Back to the precat, I think some people are thinking of the old ceramic cats that could be broken up with a screwdriver. I wouldn't know anything about that! The catalyst in my old '83 subie GL just "fell out" on it's own.....
    Mark
    02 WRX Wagon
    Registered User Kira's Avatar
    May 2002
    Aurora, CO
    I've had no problems with any of my gears. I have 4k+ miles on my car.
    "Only two things are infinite, the universe and human stupidity, and I am not sure about the former."
    Albert Einstein
    Mods: Kartboy shifter,Mobil 1 syn. AEM Short RAM, AEM Underdrive Pulley, Scorpion Axle-back exhaust.
    Auburn, WA
    mines been shifting weird since I put my BOV valve on... prolly just because the turbo isnt staying spooled and I just have to shift quicker heh!! My second gear is a pain in the ass though as well. 1st is hard to get into sometimes unless your almost stopped, so I generally never try unless I am stopped...Seems like the engagment between 1st and 2nd takes more practice to get smooth than any other engagement for me...just my .2
    95' Eclipse GST
    FP green
    720's
    02' WRX
    TurboXS Stage 2 w/Blitz SUS
    Aug 2001
    Houston, Texas
    I know you probably do not want to hear this, but I would lose the BOV especially if it is a "vent to atomosphere" model. Even TurboXS, who makes a number of BOV's and who could stand to make more money by adding a BOV to there staged packages, does not because they admit the stock BOV is excellent. Regarding first gear, mine was stubborn for a while but now at 20,000 miles the stubborness seems to have disappeared. I think 2nd gear causes grief when you "get on it" and shift early, hitting 2nd gear below boost. It bogs and can cause an unsettling thud in the driveline. Yikes!
    Mark
    02 WRX Wagon
    Auburn, WA
    Yep took to RFL off today and car is back to normal. MAN WAS IT A ***** to get the freaking stock dumb-tube back into the rubber hose coming from the intake. I literally spent 2 hours trying to get the damn clamp over the dumb tube!!!
    Finally I drilled a hole into the end of the spring clamp, opened it up as far as possible, then wrapped wire through to hold the clamp open. I then slipped it over the rubber intake hose, put the dump tube from BOV back in, slid the clamp back up and cut the wire! Voila! Finally.... has anyone else tried putting the stock BOV back on and wasted their Saturday?!?! Or am I just a moron?
    95' Eclipse GST
    FP green
    720's
    02' WRX
    Registered User DIRSGT's Avatar
    CHARLOTTE, NC
    The thing I hate is going into rev. This happened three times already. I go to go into rev and the gears grind, like i do not have the clutch engaged. So, I have to take my foot off the clucth and try again. It alwaysworks the second time around. Now, that is quriky...
    Go fast...
    2002 WRX PLATINUM SILVER
    SHORT THROW SHIFTER
    TURBO GAUGE
    WING
    ALL THE REST IS FILLING.....
    May 2002
    USA, FL
    No synchro on reverse is the reason why it grinds. I do feel though that it is not a nice reverse.
    Jun 2002
    Central IL
    I agree, reverse is normally a problem to get into. I can see the reverse lights come on behind me, but I can tell its not in reverse. So I let up the clutch and try it again and it will slip in. But I think anyone that watches me try to back out of a spot must think Im a retard!
    Rubber Duckies Fair Well in the Rain
    Oct 2002
    Like my freind who drives an 89 notchback LX once said, "If you cant find it - grind it..."
    Oct 2002
    try an awd 3000 rpm "reverse launch" in a parking lot, listen for noises, write back
    Oct 2002
    yes i am an @$$hole
