motherF@#ker, I can't believe this crap. Car won't start help asap
Results 1 to 12 of 12
This is a discussion on motherF@#ker, I can't believe this crap. Car won't start help asap within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; went outside today and my car won't start. It is getting power from the battery and the starter is turning ...
    Registered User Sharky NRK's Avatar
    Nov 2002
    Hoover, AL
    went outside today and my car won't start. It is getting power from the battery and the starter is turning the motor over. I can hear the fuel pump turn on and smell the gas if I try and crank it long enough. Car just turned to 37000 miles and the nearest dealer is 150 miles away.....what to do?
    I claim no responsibility for unintentional offense.
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    Check the connection to the spark plugs, hell check all your connections.
    No one will truely be free until nerd persecution ends.
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Also make sure the cables are securely on the battery terminals and there isn't a mound of corrosion at the connection point. This problem has 0wn3d me several times when I thought my fuel pump/something else had kicked the bucket. Good luck.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
  5. #4
    Aug 2002
    Virginia Beach, VA
    Make sure your crank position sensor is properly hooked up and engaged, a lot of people have this problem on Nasioc with standalones
  6. #5
    Nov 2002
    Hoover, AL
    will check all the connections I can get too, the car is getting power so its not a battery issue, the radio and lights work fine, just like its not getting spark. Is there a single connention that from an ignitor to the coils, cause I do not see why all 4 coils would not fire. and where exactly is the crank angle sensor located. I have the FSM but any help without having to search through that bastard would be appreicated
  7. #6
    Apr 2002
    Utah
    Not to beat a dead horse, but the problem I was referring to will make it seem like the car is getting plenty of power. This happened to me twice...I was freaking out checking coils, etc...and the starter turned over, instruments on, everything, etc. and it ended up being loose/corroded connections both times.
    Good luck.
    -- Steven Wright
  8. #7
    Nov 2002
    Hoover, AL
    I will pull the terminals and check them for good measure, can't hurt. Thanks
  9. #8
    Nov 2002
    Hoover, AL
    terminals are clean and still not nothing
  10. #9
    Registered User jibco's Avatar
    Aug 2003
    In a cube, CO
    Checked plug wire and coil connections?
    You could check the continuity and resistance if you've got a tester......
    It turns over? just no spark? Possibly remove a plug to see if it is sparking?
  11. #10
    Nov 2002
    Hoover, AL
    I am going to pull the coils off and check them as Iam out of ideas
  12. #11
    Nov 2002
    Hoover, AL
    ok pulled the coils and got spark, pulled the injectors and got fuel, tried to jump the car and got nothing. Stopped and cussed and damn near about to cry, tried it again and it fired up reluctantly. Not sure if it is running right or not, heard some funny noises but I could just be parinoid. Its idleing right and pulling the normal .57 hKPa....I will update you guys later if it acts up.
    ps, I left off that god awful plate covering the fuel rail and injectors cause it was a pain to get off and on......do I need that, it just looked like a cover to me?
  13. #12
    Apr 2002
    Utah
    Maybe your ECU is bad? I know it's rare, but it happens. Toyota had a whole batch of cars last year with fried ECUs with similar start up/running problems. Just a thought.
    -- Steven Wright
