TSB and Recall List
Results 1 to 2 of 2
This is a discussion on TSB and Recall List within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; National Highway & Traffic Safety Association Listings. Complete descriptions can be ordered through the NHTSA site or ALLDATA . Technical ...
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    TSB and Recall List
    National Highway & Traffic Safety Association Listings. Complete descriptions can be ordered through the NHTSA site or ALLDATA.
    Technical Service Bulletins
    Date of Bulletin: MAR 01, 2004
    Service Bulletin Number: 01
    NHTSA Item Number: 10006814
    Summary Description:
    CRUISE CONTROL CABLE RETAINING CLIP. *TT
    Date of Bulletin: FEB 15, 2004
    Service Bulletin Number: 063304
    NHTSA Item Number: 10006340
    DISC BRAKE PAD MODIFICATION FOR UNEVEN OR PREMATURE WORN BRAKE PADS. *TT
    Date of Bulletin: JAN 30, 2004
    Service Bulletin Number: 1511104
    NHTSA Item Number: 10006337
    SPEAKER PERFORMANCE. *TT
    Date of Bulletin: JUL 15, 2003
    Service Bulletin Number: 107202R
    NHTSA Item Number: 10002916
    COUNTERMEASURE TO PREVENT ICING IN THE EVAPORATOR ON AIR CONDITIONED VEHICLES CORRECTION. *TT
    Service Bulletin Number: 093703
    NHTSA Item Number: 10002917
    NEW WRX RADIATOR. *TT
    Service Bulletin Number: 063103
    NHTSA Item Number: 10002989
    REPLACEMENT OF THE ELECTRONIC CONTROL UNIT (ECU) FOR ANTI-LOCK BRAKE SYSTEM (ABS) REPAIR. *TT
    Date of Bulletin: MAY 19, 2003
    Service Bulletin Number: 035203
    NHTSA Item Number: 10001726
    CLUTCH PEDAL STICKING. *TT
    Date of Bulletin: MAR 21, 2003
    Service Bulletin Number: 127803
    NHTSA Item Number: 10001351
    FLOOR MAT HOOK REPAIR. *TT
    Date of Bulletin: MAR 07, 2003
    NHTSA Item Number: 10001350
    COUNTERMEASURE TO PREVENT ICING IN THE EVAPORATOR ON AIR CONDITIONED VEHICLES. *TT
    Date of Bulletin: DEC 23, 2002
    Service Bulletin Number: 035002
    NHTSA Item Number: 10000642
    NEW PROCEDURE FOR REPLACING REAR WHEEL BEARINGS. *TT
    Date of Bulletin: DEC 01, 2002
    Service Bulletin Number: 94
    NHTSA Item Number: 10000639
    IMPROPERLY MANUFACTURED 4EAT TRANSMISSION PARKING PAWL ROD. *TT
    Date of Bulletin: JUN 04, 2002
    Service Bulletin Number: 1510602
    NHTSA Item Number: 634345
    SUBJECT REGARDING GAUGE PACK REPAIR KIT. *JG
    Date of Bulletin: JAN 04, 2002
    Service Bulletin Number: 1510501
    NHTSA Item Number: 631748
    SUBJECT REGARDING AUTO DIMMING ELECTROCHROMIC COMPASS MIRROR TROUBLE SHOOTING GUIDE. *SLC
    Date of Bulletin: NOV 01, 2001
    Service Bulletin Number: 170601
    NHTSA Item Number: 626926
    INFORMATION REGARDING SEAT BELT LATCH SLIDES TO THE LOWER SEAT BELT ANCHOR. *YH
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Recalls
    NHTSA CAMPAIGN ID Number : 04V342000
    Recall Date : JUL 09, 2004
    Component: SEATS
    Potential Number Of Units Affected : 84574
    Summary:
    ON CERTAIN SEDAN AND WAGON MODEL VEHICLES, THE LEFT FRONT BOLT THAT RETAINS THE FORWARD PART OF THE DRIVER'S SEAT TO THE SEAT SLIDE RAIL MAY LOOSEN. IF THE SEAT SLIDE RAIL BOLT LOOSENS, IT WILL EVENTUALLY FALL OUT AND THE SEAT MAY SEPARATE FROM THE SEAT SLIDE.
    Consequence:
    IN THE EVENT OF A CRASH, THE DRIVER MAY SUSTAIN MORE SEVERE INJURIES DUE TO THE SEAT MOVEMENT.
    Remedy:
    DEALERS WILL INSTALL A NEW LEFT HAND DRIVER'S SEAT RAIL MOUNTING BOLT. THE RECALL IS EXPECTED TO BEGIN DURING JULY 2004. OWNERS SHOULD CONTACT SUBARU AT 1-800-782-2783.
    Notes:
    CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
    NHTSA CAMPAIGN ID Number : 04V128000
    Recall Date : MAR 10, 2004
    Component: VEHICLE SPEED CONTROL:CABLES
    Potential Number Of Units Affected : 127580
    Summary:
    ON CERTAIN PASSENGER SEDANS, WAGONS, AND SPORT UTILITY VEHICLES, THE CRUISE CONTROL CABLE COULD COME OUT OF ITS TRACK ON THE CRUISE CONTROL LEVER AND LODGE ON THE CONTROL LEVER TAB WHEN THE ACCELERATOR PEDAL IS RELEASED. IF THIS CONDITION OCCURS, THE THROTTLE WILL NOT RETURN TO THE IDLE POSITION AND WILL REMAIN IN AN OPEN POSITION.
    Consequence:
    IF THIS OCCURS DURING VEHICLE OPERATION, THE DRIVER COULD LOSE CONTROL OF THE VEHICLE, WHICH COULD RESULT IN A CRASH.
    Remedy:
    DEALERS WILL INSTALL A CRUISE CONTROL CABLE RETAINING CLIP TO THE CRUISE CONTROL LEVER TAB ON THE THROTTLE SHAFT IN ORDER TO PREVENT THE CRUISE CONTROL CABLE FROM COMING OUT OF ITS TRACK. OWNER NOTIFICATION BEGAN ON APRIL 12, 2004. OWNERS SHOULD CONTACT SUBARU AT 1-800-782-2783.
    Notes:
    SUBARU RECALL NO. WWQ-01. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
    NHTSA CAMPAIGN ID Number : 02V282000
    Recall Date : OCT 28, 2002
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION
    Potential Number Of Units Affected : 172564
    Summary:
    CERTAIN SPORT UTILITY AND PASSENGER VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSIONS WERE PRODUCED WITH AN IMPROPERLY MANUFACTURED TRANSMISSION PARKING ROD. WHEN THE TRANSMISSION SELECTOR LEVER IS PLACED IN THE "P" (PARK) POSITION, THE TRANSMISSION PARK MECHANISM, THAT IS INTENDED TO HOLD YOUR VEHICLE, MAY NOT ENGAGE.
    Consequence:
    THE VEHICLE COULD THEN MOVE/ROLL WITHOUT PRIOR WARNING, INCREASING THE RISK OF A CRASH.
    Remedy:
    DEALERS WILL REPLACE THE AUTOMATIC TRANSMISSION PARKING ROD ASSEMBLY. OWNER NOTIFICATION JANUARY 8, 2003. AN INTERIM OWNER NOTIFICATION WILL BE SENT DURING NOVEMBER 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT SUBARU AT 1-800-782-2783.
    Notes:
    CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
