Results 1 to 4 of 4
This is a discussion on A couple not so common service questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; First, is it OK to do your fluid changes (oil, diff, trans) with the front 2 tires up on gator ...
    Registered User Blue2004WRX's Avatar
    Jul 2003
    Syracuse NY
    First, is it OK to do your fluid changes (oil, diff, trans) with the front 2 tires up on gator ramps? I've read somewhere that your car should be perfectly level, but I'm not small enough to crawl under the car.
    Second, what kind of washer goes around the plugs for the transmission? I read you need to replace them everytime you do it, but im sure as hell not going to go under there and pull it out to look.
    Thanks
    --2004 WRB WRX--
    Still way too stock.
    Originally posted by MidnightFLAT4
    I like A/C for the sole reason that it makes the idle sound meaner.
    Jul 2003
    Syracuse NY
    ttt. this is important!
    --2004 WRB WRX--
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    There's nothing wrong with putting the car on ramps to cahnge the oil. It does increase the amount of oil that will remain in the pan but the amount is miniscule.
    Can't help you with the Tranny washer. Go to the dealer and pick some up.
    Jul 2003
    Syracuse NY
    Thanks. I guess I'll go to the dealer for the washer, but it's a pain because it's like 40 minutes from my house.
    --2004 WRB WRX--
