Help! Made big mistake - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
This is a discussion on Help! Made big mistake within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; holy s*&t dude that is the funniest thing i have ever read about changing oil you're lucky you didn't put ...
    Registered User subaru_crazy's Avatar
    May 2004
    NYC
    holy s*&t dude that is the funniest thing i have ever read about changing oil you're lucky you didn't put the transmission oil into the engine it self BTW not all transmission fluids are the same did you check what subaru recommends to put in???
    MY LUG NUTS NEED MORE TORQUE THAN YOUR HONDA MAKES!!!!
    Cobb Stg 2 helix up/dp combo
    Kartboy short shifter
    Registered User Retro's Avatar
    May 2002
    USA, FL
    Quote Originally Posted by tarbaj
    Before you write off any brand. Are you sure you installed it correctly. The old gasket was gone and you didn't overtighten the new filter. You don't use the nut on the end to put the filter on. you'll crush the gasket and it will leak.
    Yup, I'm pretty sure everything was installed correctly, and I tightened it by hand at first (but I'm very weak ). I've done 2 oil changes before so the procedure is not new to me.
    clutch, shift, gas, clutch, shift, gas, shift, clutch, gas, clutch gas, shift... oops!
    May 2004
    NYC
    i do my oil changes all the time and just tighten the filters by hand,and it doesn't have to be on there all that tight, I never had a leak. I tighten it so that next time i change it, i can always just use my hands to unscrew it as well, without any major effort. I always moisten the rubber gasket with some oil before i put the filter back in place.
