TECH: 60K maintenance?
Results 1 to 15 of 25
This is a discussion on TECH: 60K maintenance? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; awsome man! thanks alot... What brands of things should I get? Also what is a good place to get them ...
    Registered User tasq's Avatar
    Jun 2004
    Lafayette:CO
    Also what is a good place to get them all at once?
    2005 CGM WRX / 1994 Legacy Turbo Wagon
    Do not believe that you do not control your own fate.
    Jun 2004
    Lafayette:CO
    No new belts or anything? I guess that would be at 90K
    recommended brands?
    Registered User scooby24's Avatar
    Mar 2004
    Kansas City
    how hard is it to replace spark plugs on these mofo's?
    05 Crystal Gray STi
    304 hp 353 lbs on 92 octane ------> Mustang Dyno
    12.6 @ 109.2 > new numbers coming soon.
    Jun 2004
    Lafayette:CO
    I've yanked my plugs before... It is pretty easy just make sure you use NGK brand
    Edit: My car is a 2.5 RS though....
    Registered User Mad WRX's Avatar
    Apr 2002
    Denver
    recommended brands?
    I've never done belts or anything, someone else might be able to come help us with those
    Jun 2004
    Lafayette:CO
    I'm not sure if they are part of the 60k or not... I emailed joe at flat4.... I will ask him...
    Jun 2004
    Lafayette:CO
    just found this all allsubaru.com...
    Change gear oil
    Flush and service cooling system
    Change brake fluid
    Tune engine
    Change spark plugs (2.5 L and SVX at 60,000 miles)
    Perform induction & intake system service
    Clean throttle assembly and linkage
    Adjust carburetor (if applicable)
    Change distributor cap and rotor (if applicable)
    Engine compression check (2.5 L and SVX if applicable)
    Set engine timing
    Check engine computer for fault codes
    Test/service battery
    Adjust ECVT switches (if applicable)
    Jun 2004
    Lafayette:CO
    Think we can handle all that?
    So far I have bought
    Brake Pads Front - Ultimate MY02 (AXXIS)
    Brake Pads Rear - Ultimate (AXXIS)
    Intake - Flat Panel (Perrin)
    Oil - Differential 75w90 (Redline)
    Oil - Transmission 75w90ns Shockproof (Redline)
    Spark Plugs - Iridium (NGK)
    Registered User WRXturboAWD's Avatar
    Oct 2003
    Aurora, CO
    It took Zoombaru and I two hours to do mine, but that was with letting the car cool down, so if your engine isn't hot, give or take about an hour and 15 mintues.
    -Dan
    Da Ghetto Rig
    Jun 2004
    Fort Collins
    spark plugs...
    After doing it twice in two weeks... I recommend:
    a. let the car cool down or wear gloves
    b. USE NGKs!!! (I decided to try and go with autolite and my car was UNHAPPY
    c. don't forget to plug the MAF back it.
    d. take the battery out also
    I used a flex head ratchet, 5/8 spark plug socket, and a 3 inch locking extension. plus a 12mm socket to get the coils off each plug. I couldn't have really used anything else. the scoobymods directions have you using almost every tool in the shed, and I got 'em out, but didn't use 'em.
    This isn't to big a deal, just a pain to take out wper fluid res, battery, and airbox... especially when the engine isn't cool...
    Jun 2004
    Lafayette:CO
    Anyone else with experience? Anything missing?
    Registered User Ry-Guy's Avatar
    Nov 2003
    Thornton
    My spark plugs are easy, no battery under the hood and the filter sit on top of the throttle body. I remove 2 screws for the washer resevoir and I'm ready. hehe, other than that everything on that list has been done more than once except the fuel filter and coolant. I could afford to do a few of those items soon though, I've got 52,000 on the clock. Haven't done a compression test, but I did a leakdown test on Thursday: 9% on three of the 4 cylinders, and 15% on the other. Compression test I would imagine is good as well.
    -Ryan
    Thanks!
    Jun 2004
    Lafayette:CO
    How do you accomplish those?
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    I started doing mine. I changed the rad hoses as my top one was bloated and split inside. my coolent was nasty with floating things in it. I checked the suspention parts and all looked but but there is some heavy wear to the end links so I think I will replace them. I think I will have the trans and diff serviced as I am to lazy to go that far. even though I know the fluids look good. my timming belt was recently looked at so I am not going to sweat that. belts looks good. just did oil change. brake fluid flush (suggested) was looking nasty with crap in it. I still have yet to change the spark plugs. wanted more opinions on them. was looking at NGK iridium ix. any thoughts? I looked over my brake pads but looked good. So at this point am I missing anything? besides air filter.
    thanx
    2002 wagon 83k miles
    perrin short ram, inlet & fmic, perrin / samco hoses and fuel rails, bosal dp. erz upp, borla catback, sti ra gears w/ stock 5th, act clutch & fly, vf30, AP, perrin end links, critical cooling kit, hks bov, perrin 4pot brakes, rota wheels, hid w/ levals
    Racenut3.0 - said
    "The worst thing about the AP is it did not come with any fairy dust. I wanna fly dammit!"
    Jun 2004
    Lafayette:CO
    always use the ngks!
