Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
This is a discussion on TECH: 60K maintenance? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; reasion I ask as I would think ngk offers several plugs for this car. so what works best for say ...
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    reasion I ask as I would think ngk offers several plugs for this car. so what works best for say soon to be stage 2.
    2002 wagon 83k miles
    perrin short ram, inlet & fmic, perrin / samco hoses and fuel rails, bosal dp. erz upp, borla catback, sti ra gears w/ stock 5th, act clutch & fly, vf30, AP, perrin end links, critical cooling kit, hks bov, perrin 4pot brakes, rota wheels, hid w/ levals
    Racenut3.0 - said
    "The worst thing about the AP is it did not come with any fairy dust. I wanna fly dammit!"
  2. #17
    Jun 2004
    Fort Collins
    I tried some Autolite plugs in my car... gapped them to factory spec, but man, the wrx DID NOT like the autolites. I drove all the way to F.A.S.T. (Aaron really is cool) on saturday afternoon just to get the NGK's, although if I were to do it again i'd just order them from an Auto Zone for cheaper. I was freaked though... The car had never been so unhappy. I'll always go with OEM plugs now. I had an extensive conversation with Prodrive about plugs and they've never noticed ANY difference with their setups and OEM vs. colder plugs, so I wouldn't mess with it. Especially at this altitude. with slightly less O2 in their, we really aren't concerned about detonation, and putting colder plugs in is just gonna delay ignition that much more putting the timing dangerously early if things ever did spark hot.
  3. #18
    Registered User Mad WRX's Avatar
    Apr 2002
    Denver
    Originally posted by tasq
    Think we can handle all that?
    So far I have bought
    Brake Pads Front - Ultimate MY02 (AXXIS)
    Brake Pads Rear - Ultimate (AXXIS)
    Intake - Flat Panel (Perrin)
    Oil - Differential 75w90 (Redline)
    Oil - Transmission 75w90ns Shockproof (Redline)
    Spark Plugs - Iridium (NGK)
    You get brake fluid?
    Try to find some clear plastic hose that we can use to bleed the brakes.
  4. #19
    Registered User tasq's Avatar
    Jun 2004
    Lafayette:CO
    sent you a pm about your choice of fluids! Also what size / length of hose?
    2005 CGM WRX / 1994 Legacy Turbo Wagon
    Do not believe that you do not control your own fate.
  5. #20
    Apr 2004
    lancaster
    ok let ask this... What is on the list for things to do at 60k service? can anyone tell me that. also what ngk plugs are suggested? just regular or is there a spacific one?
    thanx
  6. #21
    Jun 2004
    Lafayette:CO
    always use ngk plugs.
    http://www.allsubaru.com/schedules.html for a list
  7. #22
    Apr 2004
    lancaster
    ok thanx on service info
    but the ngk is there a spacific plug that work best of the ngk line up for this engine? I dont know much about it. example vw golf gti 8v for bosch plugs. platnam regular, +2, +4, super 3 prong. if there only one ngk plug that is made for this car or are the a few choices. if choices what one is what I am after.
    thanx
  8. #23
    Apr 2004
    lancaster
    is 60k also the time to have the clutch fluid changed?
  9. #24
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    thanx
    Spark Plug Sticky
    it depends on your level of modification. i'd suggest sticking with platinum, stock heat range until you get to a stage 4 (upgraded turbo)
    then i'd go one step colder. in the linked thread above, there is somd good info on plugs that fit, but come with a gap that is too big. typically some adjustment of gap is required anyways, but making larger moves is less desirable than just tweaking a small move.
    dR
    [EDIT] when i swapped out my plugs at 60K, they were still fine, and easily could have gone another 30K without any problems. probably more.
  10. #25
    Aug 2001
    The Hub
    tranny fluid. and yes. it's a good time.
