OIL amount on oil change!! - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on OIL amount on oil change!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Agreed. 0.2 over won't hurt anything....
    Registered User Saabarunian's Avatar
    Aug 2004
    Philly PA
    I'm pretty sensitive to overfilling. Apparently high levels can lead to excessive mixing of air into the oil (foaming) which is dangerous due to decreased lubrication. Better to be a half quart under than over.
    (BTW, if I don't change it myself, I ALWAYS check it after. A year ago one garage accidently put two and a half quarts too much in right before I was going on a long trip. I had to drain it out in the middle of the night and I was pi**ed but they were really good about it and gave me two free changes later.)
    Registered User Mr. Poon's Avatar
    Jul 2004
    Ellsworth, ME
    The manual on my 05 WRX says 4.2 and I initially put that much in. The level looked fine, but dropped after I started it and let it run for a bit. Assuming the "lost" oil was now in the new filter, I added another half quart or so and it's now right at the full mark.
    2009 WRX 5Door- Silver
    2008 Toyota Tundra SR5 Crewmax
    1957 Willy's CJ3B, '73 Corvette Yellow
  6. #19
    Registered User fsidesmith's Avatar
    Jul 2004
    Burlington, VT
    Well, sounds like you're right around 4.7 quarts. Your rex is probably happier now.
  7. #20
    Jul 2004
    Ellsworth, ME
    Oh, it's happier alright. Much happier than, say, the two idiots in the Grand Am that were going intentionally slow on the way home from work this evening, only to floor it when I moved out to pass them. I was going to downshift into 3rd but figured, why bother? No need to.
