Whats the BEST OIL - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
This is a discussion on Whats the BEST OIL within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; German Castrol is supposed ot be great, too. It's also green and smells like gummi bears....
  1. #31
    Registered User Judas's Avatar
    Nov 2003
    North Pole, Alaska
  3. #32
    Registered User toxin's Avatar
    May 2004
    Kiev
    Question
    Hey guys,
    Can anyone tell something about Texaco Synthetic oil 5w30 or 5w40 ?
    Can I use any of em in my '02 rex?
    Thanks.
    Toxin
  4. #33
    Registered User FormerlyEuro's Avatar
    Nov 2004
    Quote Originally Posted by JnJassociates
    Amsoil. Worth every penny.
    +1
  6. #34
    Registered User WRXcelration's Avatar
    Apr 2004
    Allentown PA
    i use M1 5w30 and a M1 filter
    05 STI
    Speed Comes At A Price...How Fast Can You Afford To Go?
  7. #35
    I understand the advantage of peanut oil - it has a higher flash point than most other cooking oils, so you can use it at very high temperatures and it won't smoke up on you. Still, there's nothing like using olive oil with a little lemon, some oregano, some pepper, and a touch of salt on a nice steak on the grill. I say olive oil for everything except stir frying where the recipe dictates peanut oil. I'm no gourmet but I do weight over 100 kg so my opinion is not to be taken lightly...
    For the car's motor I use M1 in my Impreza (see my oil analysis data post) and Castrol in my MR2.
  8. #36
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Since I got my JDM motor I've been using Mobil1 0W-40 and it's been great. I haven't had issues with burning.. When the winter passes I think I'm gonna bump up to 5W-40 but that's still debateable.
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
  9. #37
    Registered User Shifty's Avatar
    Jun 2004
    Corvallis OR / OSU go BEAVS
    Huh? Maybe this is bad. Just had my oil changed today at Jiffy Lube, they put Quaker State synthetic in. Well at least its better than regular pennsoil. Do most of you guys do it yourself?
    TINA..... come eat your ham!!!
    04 white wrx wagon stage 2.5
  10. #38
    Registered User TheBoostCreep's Avatar
    Apr 2004
    Merritt Island
    Since this topic was brought back up, and I'll be changing my oil this Saturday, is there anything that needs to be done when switching from regular oil to synthetic? I've just been using Castrol 10w30 for the first 15,000 miles and want to switch to synthetic now.
    Sounds like either Mobil 1 or Amsoil is what I'll go with. Price/availability will determine that.
    Just wondering if I need to do anything special after draining my Castrol oil before replacing with synthetic. thanks!
    I'm TheBoostCreep, and I approved this message.
  11. #39
    Registered User tarbaj's Avatar
    Jul 2004
    Livonia, MI
    Just a thought here. Amsoil has been proven to be #1 by a very slight margin vs Mobil 1. I had my oil (Mobil 1 5W-30) analyzed at 7K miles and was told there was plenty of life left in it. They recommended resampling at 8K. I'd bet it could go 9 at least.
    What you also have to consider is availability. I can get Mobil 1 anywhere. Amsoil is not found easily. Mobil 1 is also cheaper. Both will keep your EJ purring like it should. If you want to stock Amsoil in your garage/basement go for it and you won't be disappointed. If you want to be able to go to the store and buy the 5 Qts and save some $ when you need to change oil go with Mobil 1.
  12. #40
    Quote Originally Posted by TheBoostCreep
    Nothing at all. Just pour in the new stuff as normal. One thing to be cautious of is extending the drain interval initially though; you have no idea what the wear numbers and rates might be with the new stuff (granted, they are almost certainly going to be well beyond "acceptable" and closer to "excellent" but still, you have no personal data) and also, the motor will have a bit of the old fill left in there, including the older additive package -- implying you might not be truly running a good synth with its additives only until after the second drain.
    For example, my first data with Mobil 1 5W-40 show some molybdenum, and the oil has next to none. The source, therefore, was my previous oil (Mobil 1 also, but 10W-30 and -- surprise! -- that formulation had molybdenum). Still, no worry at all. My advice is to just go for it.
