EGT sensor came out (HELP)!
Results 1 to 4 of 4
This is a discussion on EGT sensor came out (HELP)! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; the sensor is just laying there directly across from where it threads in... i'm not sure how it came out! ...
    Registered User poopymailman's Avatar
    Feb 2004
    olympia, wa (yes it's the capital)
    Question EGT sensor came out (HELP)!
    the sensor is just laying there directly across from where it threads in... i'm not sure how it came out! anyone ever have this happen? PLEASE HELP! i don't think anything will happen to the engine, any feedback on that also would be appreciated! my car sound like a freekin' old VW bug! cool to a certain extent, it just enhances the boxer rumble! a lot!!!
    thanks in advance
    ryan
    Registered User BigRich's Avatar
    Aug 2001
    Lexington Park, Maryland
    This happened to me last year. It just shook itself loose over time. Since I had a constant CEL indicating the EGT probe was bad anyway I simply replaced it with a bolt coated in copper gasket maker. Not sure if the gasket sealer made any difference but I checked it the other day when I installed new plugs and it hasn't moved.
    As for the EGT probe I tossed it and plugged a resistor from Radio Shack into the wiring harness. Here's the tutorial
    -- Rich
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    High temp Loctite or else just get a catless U/P and scrap the EGT gauge
    I don't think anything would happen to your engine but you'd have a big hole pre-turbo so you'd lose a lot of boost. But best bet is to put it back or plug the hole ASAP.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    May 2004
    I used regular locktite and a lock washer and haven't had any problems.
