Results 1 to 2 of 2
This is a discussion on What tools do you use? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi, I'm building up my collection of tools. I am just wondering what is needed to do most of the ...
    Nov 2003
    Hi, I'm building up my collection of tools. I am just wondering what is needed to do most of the work/modding that I am going to be doing. Here's what I have.
    10-18mm box wrenches
    10-17mm sockets
    10-15, 17, 19mm deep sockets
    10-17mm nut drivers
    rachets + 6" extension
    needle nose pliers/wire cutter
    10 peice screwdriver set
    Ironclad gloves (like Mechanix)
    I may need a 19mm box wrench, and a 2nd 14mm box wrench.
    I should probably buy an oxygen sensor wrench.
    Any sizes that you end up using a lot? I've seen 10, 12, 14, and 17 the most I think. Don't know if the 16 and 18 are even worth having.
    Former car: 2002 Cobb/Scoobysport stage 2 WRX sedan
    New ride: ???
    cnk
    cnk is offline
    NJ
    Those are pretty much it to get you around most of the car. I would also suggest a good torque wrench and breaker bar. Jack stands, ramps, jack, sparkplug socket, 1/2" ratchet for the rear diff, and I believe it's either a 21 or 22mm socket for the tranny drain bolt.
    Calvin
