Results 1 to 8 of 8
This is a discussion on radiator turns on befoe I even start the engine? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This morning I was cleaning my interior and put the radio on, turning the key to the last position before ...
    Registered User blackboost's Avatar
    Jul 2003
    New Haven
    This morning I was cleaning my interior and put the radio on, turning the key to the last position before ignition. I had't driven the car at all and the engie was cold, but the radiator fan started blowing. Has anyone else experienced this? It semed fine once I started driving, it wasn't even hot today, 75 tops. Thanks
    catless Cobb stage 2
    "That's only a v-4! My v-6 will beat you anyday" - dumbass
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Is the two green connecters (I think there both green?) plugged up?
    I believe it go,s into a kinda test mode, Peek under the dash at the bottom under the steering colum and check em out.
    Otherwise.............I dunno
    Shotgun
    Jul 2003
    New Haven
    should the green connectors be plugged up? what do they normally do? thanks
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    if the car is driving normally, it's not the green connectors.
    they put the car into limp or diagnostic mode. leave them unplugged.
    that has nothing to do with the radiator fans coming on.
    was your A/C or defroster on? i would suspect you were hearing that.
    dR
    Jul 2003
    New Haven
    I opened the hood before I started the engine and I saw it was definetely the radiator fans. I'm not going to worry about it since she's driving fine. thanks for the feedback guys
    Jul 2003
    New Haven
    I'm a moron. It was the front defroster, apparently it automatically turns on the AC. If anyone else has this problem, this is probably the reason. I thought the car felt sluggish the last few days!
    cnk
    cnk is offline
    NJ
    Just remove the little microswitch and you can run the front defroster without it kicking in the A/C.
    Calvin
    Aug 2001
    The Hub
    Calvin
    it can be done. but have fun driving with fogged windows.
    it's set up like that b/c its effective.
    dR
