Question about Timing belt
Results 1 to 15 of 21
This is a discussion on Question about Timing belt within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am getting up there in the miles, and I feel I should change my timing belt soon. Unfortunatly I ...
    Registered User power091999's Avatar
    Jul 2003
    I am getting up there in the miles, and I feel I should change my timing belt soon. Unfortunatly I am kinda broke, and will be for a while. I can't really afford a 130 belt.
    My question is would any of you take the chance with a used timing belt for MUCH cheaper?
    Said belt has about 6000 miles on it.
    Any input would be cool. Thanks.
    Oct 2003
    Brick NJ
    First how much cheeper...
    second....NO
    Jul 2001
    Plains of Eastern Montana
    How many miles on your current belt? IIRC it's over 100,000 miles in the schedule- I probably won't wait that long, but no sense going in too early.
    I think the belt will be the least of your costs- I don't think this is a shade-tree operation- I'm guessing some Subaru "special tools" involved.
    Big Sky
    Registered User jmussetter's Avatar
    Feb 2002
    Bay Area, CA
    No special tools required. You need a C-clamp to press the tensioner pin back into place before re-installing the belt.
    Other than that, you'll have a LOT more room to work if you remove the radiator and fans to get to the timing belt. That should give you 4-6 inches extra room in front of the timing belt to get wrenches and stuff in there better. The radiator and fans come out SUPER easy.
    -jason
    2002 Midnight Black WRX - EJ22 w/ VF30 and all the other stuff to go with it...
    ***ATTN: Speed Kills! Drive a Honda and live FOREVER. ***
    Feb 2002
    Bay Area, CA
    I just wanted to add, that if you put your mind to it, there isn't anything that CAN'T be done. After just finishing a complete motor swap that all took place in my apartment's CARPORT!!! All without my landlord ever finding out.
    After completing that, ANYTHING can be a "shade-tree" project.
    SubaruWRX2k4: Good luck if you tackle the timing belt yourself...
    -jason
    Jul 2001
    -jason
    That's good to know- the radiator is a breeze to take off. The crank pulley just takes a little umph to get off, what about the crankshaft socket they show- is it just a normal socket or is some weird shaped deal?
    Also when doing a timing belt what else should be done- waterpump, tensioners, any oil seals?
    Also appears there is a right way/wrong way to move the cam sprockets when installing the belt- is absolutely necessary to even move the sprockets to install the belt?
    Big Sky
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    Big Sky
    bump for all those good questions.
    also, what mileage is everyone doing this? I know the typcial number used to be 60 to 75K, and i'm approaching that zone.
    dR
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    whats a average price to have it done. what belt do you recomend? I understand there are some belts better then oem.
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    doing timing belts is difficult if you have never done one before. If you dont have all the cam pulleys lined up right, you could bend a valve or your car wond start. I would really make sure you know what you are doing, because you can damage some stuff if you dont.
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
    Aug 2003
    Norway, Europe
    Re: Question about Timing belt
    I would NOT put in a used belt.. The point of changing the belt is to get a new one in there...
    The belt it self is not that expensive. The dealership install will cost you more. If you plan on doing it yourself read all you can before you go ahead and bring a clever friend. You do not want this done wrong.. If you don't have clue how it's done I would let someone else do it..
    I'm not sure when it's recomended to change the belt, but my service book says 100.000km (or every 4 year) on my euro edition.
    I ruined a engine in my old audi a4 because of an timingbelt that was old. Time for a change on my rex soon, I'm not sure I want to do it myself, I'll have to read alot first to se if I understand everything that needs to be done before I start.
    PS I belive it's recomended to change the automatic belt tension adjuster or what it's called.. If this fails you don't have much use for you new belt..
    Silver -02 Impreza WRX
    Aug 2001
    The Hub
    dR
    bumper!
    Administrator
    May 2003
    Big Sky
    Definately remove the rad and fans, it makes life a lot easier. The crank pulley comes off with a regular socket. If you have a gun it makes life easier. Set the engine at TDC and remove the belts covers and pulleys. Then remove the belt. When reinstalling, line up the necessary marks, and adjust the tensioner to the necessary tension. At this point, put the crank pulley back on the car without reinstalling everything and slowly turn the motor over two complete revolutions by hand with a ratchet or breaker bar to make sure the valves aren't hitting the pistons from misinstallation. It you feel a hard resistance, don't force it. Back it up and check your marks. IF everytings spins well, put it back at TDC, check your marks, and close 'er up. It is always smart to change the water pump, tensioners, and oil seals when doing this job, but not necessary.
    Administrator
    May 2003
    dR
    When it comes to timing belts on interference motors, the sooner the better.
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Originally posted by trainrex
    Definately remove the rad and fans, it makes life a lot easier. The crank pulley comes off with a regular socket. If you have a gun it makes life easier ...blah blah blah blah... water pump, tensioners, and oil seals when doing this job, but not necessary.
    Methinks you've done this a time or two...
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Administrator
    May 2003
    Lol....just a few
