Don't pry it off, instead put the screwdriver between the bearing and pressure plate and twist it...it should pop out easily.
This is a discussion on How to remove release bearing? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm installing a new engine and it says to remove the release bearing from the clutch plate with a screw ...
I'm installing a new engine and it says to remove the release bearing from the clutch plate with a screw driver and then intall it onto the tranny shaft. I can't figure out how to get it off the pressure plate at all. Anybody know how? I'm confused about where to pry at it with the screw driver. In the picture do you pry directly after the bearing, or where you can see kind of a sline pattern in there? Thanks for the help in advance
