Results 1 to 15 of 21
This is a discussion on HELP!!! Engine revving by itself!!! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; On the way back from visiting some friends the other day, my car starting reving on its own out of ...
    Registered User Rippa's Avatar
    May 2003
    On the way back from visiting some friends the other day, my car starting reving on its own out of no where! I was in neutral the whole time it was reving. It was steady reving not pump reving. It started on its own at about 1000 rpms then gradually went up all the way to 3500 rpms. I pulled over and checked some vacuum lines but didn't see anything out of place. So I turned the car off then on but it started up again, only this time it didn't rev so high, it was back down to about 1500. So I drove home and after taking it through fifth, it calmed down and was back to normal at 500 rpms at idle. I took it out today, everything was smooth until about half an hour into the ride and it started up again!! Oh yea, its not the recent clip for the cruise control, I had that done to see if that solved the problem but it didn't. So its gotta be something else. I don't know what's wrong. Can anyone help??? Has this happened to anyone else???? Any and all info would be greatly appreciated!!
    Will
    Dec 2002
    Calgary, Alberta
    Sounds like a throttle position sensor. If it were me, I would start there.
    Registered User rallymaniac's Avatar
    Nov 2003
    Special Stage
    sounds like somthing i experienced with a rental car that i rented for Rally Deutschland last summer in Europe. It was Ford Mondeo and was doing the same thing. When i was driving the revs wouldn't go below 3500 and same thing in neutral. It turned out to be a MAF sensor. I returned the car. I was thinking about driving it but a friendly mechanic told me that it will continue doing it for a while and later the car will just die and not start again untill you take care of it. YOu may wanna give MAF a try.
    Straights are for fast cars...
    Turns are for fast drivers...
    Colin McRae
    My PHOTOGRAPHY
    Registered User driverj's Avatar
    Jan 2003
    Could it possibly be related to the cruise control recall? Have you taken it for that?
    Nov 2003
    Special Stage
    -/\/\/\/\- did you read his post???
    Colin McRae
    My PHOTOGRAPHY
    Jan 2003
    Not the whole thing. I stopped half way.
    May 2003
    Well I got rid of the revving problem!! It was the throttle and cruise cables, They were too tight!! So I loosened them and the car is as good as new again!! So thanks for all the input, it was greatly appreciated!!
    Thanks again,
    Will
    310whp / 309trq @ 19psi
    Now with 6 Flavors of JDM Goodness!!
    MODS
    Jan 2003
    So I was right but wrong at the same time.
    Good to hear.
    Sep 2001
    Edmonds, Washington
    Your idle should be around 700-750, 500 is too low.
    http://homepage.mac.com/supermarkus/PhotoAlbum1.html
    Mullet haiku:
    Daughter's BMX
    Takes me to welfare office
    Trans Am is on blocks
    Mar 2002
    Tokyo, Japan
    Good to hear.
    Ignoring the thread and still getting the right answer. Good work
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    Do you have a aftermarket BOV? I had this happen to me twice as well, hasn't done it in over 15000 miles though. I believe in my case it was the piston of the BOV getting stuck. Problem was exactly the same as you desciribe yours.
    autobahn storming scooby
    Jan 2003
    I was actually reading what he wrote but I may have gotten distracted (shinny things). I remember reading the 1st half and just spewed an answer without reading again. Possibly Adult ADD.
    Registered User AWDrifter21's Avatar
    Sep 2003
    NJ
    idle should be 500 rpm stock....
    when I installed by BOV and then put my stock bov back on, i lost the recirc hose so I had to drive to subaru to pick one up and my idle was flucuating like crazy, but when driving, the stock BOV sounded just like the HKS, but not as loud... .
    I think the stock BOV rocks if it was strong enough for 100% atmospheric., sorry for robbing the thread
    anyways, what do you think could have cause your throttle and cruise control cables to get messed up like that?
    AWDrifter
    Registered User Mad WRX's Avatar
    Apr 2002
    Denver
    750
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
