Oil drain plug will NOT stop leaking - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on Oil drain plug will NOT stop leaking within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Regardless, you might look into a skid plate - metal, not plastic. Search "primitive" on this site....
    Registered User Matt-'s Avatar
    Dec 2003
    Mclean, VA
    If you go back to the dealer make sure you take off any mods. Your BOV might be causing the oil plug to leak...
    ...carry on...
    Originally posted by MainFrame
    I have almost 45k miles now, so it's not under warranty anymore.
    You know, the 5yr/60Kmi warranty does cover the oil pan, oil gaskets, and seals. I should have seen this sooner, but I was looking through my booklet today... The issue will then become whether you stripped it or not though.
  6. #19
            MainFrame's Avatar
    Austin, TX
    ...carry on...
    It's an OEM recirculator.. unless this is a common problem on all WRXs I doubt it's the recirculator causing the oil to leak.
  7. #20
    Dec 2003
    Mclean, VA
    Sorry man, I was just making a joke about dealers trying to find a mod that is causing any problem.
  8. #21
            MainFrame's Avatar
    Austin, TX
    Doh!
    Anyways... I guess I'll go ahead and get the fumoto for my next oil change and see if that stops the leak.
  9. #22
    Registered User OffRoadWagon's Avatar
    Jul 2003
    Wisconsin
    I like the Teflon idea (BTW, teflon tape is golden, not ghetto. Check it out on DuPont's website if you like. That stuff is super amazing.) But, you'd have to make sure you torque it correctly with that stuff, cause it does make it easier to turn, and therefore easier to overtighten.
