Results 1 to 5 of 5
This is a discussion on Looks like I will be changing my own oil from now on. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I went to the dealer today to get it done. It was cold outside So it ended up being like ...
    Registered User Steve-o's Avatar
    Aug 2002
    I went to the dealer today to get it done. It was cold outside So it ended up being like $60! $60! sixty dollars!
    How much is mobile 1 synth anyways, they charged me 7.99 a quart X 5?
    Only good part about it was they washed the car... followed by it getting rained on an hour later.
    WRB WRX: Super 16g Equipped
    www.BrotSpec.com
    Mobil1 is roughly $24 US in a 6-pack box at Costco. For those that don't mind supporting poor labour practices, Walmart routinely sells 5 qt jugs for $22 or less (as low as $18ish). A quart of the stuff by itself should not be above $5, and can be had for as low as $3,50 on a good day.
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Sounds about right for dealer service. Except that the WRX is the easiest car in the world to change the oil on. Takes about ten minutes.
    $24 in M1 + $5 filter + $0.50 crush washer + ten minutes of your time.
    -Jim
    Registered User DROB's Avatar
    Feb 2003
    Port of the Cow,Texas
    Easy as hell to do....I don't miss my civic either. Changing oil on that car was a *****.
    Dom
    03 Platinum Silver WRX
    Registered User bdoug's Avatar
    Aug 2002
    NE Ohio
    Yeah, Civics are a PITA. no matter how careful you are a little oil always drips out the filter on the exhaust.
    THE INTERNET: Where men are men, women are men, and the children are FBI agents.
