CEL code
Results 1 to 5 of 5
This is a discussion on CEL code within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; ok had my code pulled at autozone and it came up as a po304. missfire in cylinder 4 what can ...
    Jul 2003
    waukesha,wi
    CEL code
    ok had my code pulled at autozone and it came up as a po304. missfire in cylinder 4 what can i do to fix this. i have nothing major done to my car. i have a blitz racing spec cat back and just install an egt gauge. i took it to the dealer once and i think they just reset it.they said they had to send the ecm to subaru
    light came back on few days later so i took it in and had the code pulled. is this something to worry about?
    Jul 2003
    waukesha,wi
    wow not one person has had any problems like this
    Jul 2003
    waukesha,wi
    wow so helpfull around here
    Registered User wRxOne's Avatar
    May 2002
    Vallejo, CA
    Check your sparkplugs for detonation or just compare it to another plug for discoloration, having that on a new car is something to worry about but your dealer should fix it under the warranty. If they did however actually replace your ECU you shouldn't have any further problems, could be a simple timing issue...
    -alex
    Jul 2003
    waukesha,wi
    thanks for the input i plan on checking my plugs this weekend. also did some looking around and was told that since the CEL came on at idle that if it did miss fire shouldnt cause any problems. thanks again for the response
