Syptom: vibration when braking at high speeds
Results 1 to 6 of 6
This is a discussion on Syptom: vibration when braking at high speeds within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my friends thinks it's because my rotor(s) are warped. The fix will be new rotors. I get the vibration ...
    Registered User QuickSilver's Avatar
    Bay Area, CA
    I get the vibration only at speeds greater than 70 mph and it's only during the initial decelleration (read: does not keep vibrating).
    Is there anything else that could cause this?
    opinions?
    thanks,
    Dan.
    '02 Plat. Wagon, Manual
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    First thing that came to my mind was warped rotors, but I know someone that had a similar problem and it was fixed from just new pads.
    Do you use a torque wrench on your wheels? Uneven lug torque is about the easiest way to warp a rotor.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    This is pretty common. My theory is that the stock pads have a bad out-gassing problem. Switching to aftermarket pads cured this on my car.
    C
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Bay Area, CA
    Clarification:
    I have Hawk HPS pads on...installed about 5 months ago.
    I did have an incident where a loose lug resulted in the stud breaking off my front left wheel...the wheel itself became dangerously loose. I had it replaced at a reputable garage.
    The vibrations happened well after that event, so that's why I didn't think it directly correlated.
    How can I tell if the rotors are indeed warped? or if the pads are bad. It's cold here in MI...don;t really want to mess around w/ the car too much...
    thanks for your input,
    dan.
    Jun 2002
    LOL. I kinda thought you'd been around long enough to know about the stock pads, Dan!
    Use one of these to measure it. You might be able to rent/borrow one from an autoparts store:
    http://www.hswtools.com/store/mercha...tegory_Code=ST
    Try getting your wheels re-balanced. It's certailnly possible for an out of balance wheel or out of round tire to only show up as vibrations under deceleration forces.
    You'd probably feel warped rotors at all speeds.
    C
    1993 Honda CBR600F2
    Bay Area, CA
    [QUOTE]Originally posted by GV27
    [B]LOL. I kinda thought you'd been around long enough to know about the stock pads, Dan!
    ??? What about the stcok pads? I did a search..nothing.
    ...and even tho I've been around, I still come across "blind-spots" in my "training"
    I swapped back to stock wheels and tires for the winter and there's still vibration. So I don't think it's a wheel balancing issue.
    I just wish it was warm enough for me to pull them off and inspect them properly...for now, unless people think it's a BIG mistake...I'll try to ride out the winter the way it is.
    dan.
