i would stay away from the dealer. i would say go to a tire place like sullivan tire, or direct tire. price it out with them the dealership's maintenance are way inflated.
use NGK plugs.
i'm about to do my 60K service, here's the list i'll be taking to the mechanic.
OIL & FILTER CHANGE
ALIGNMENT
ROTATE TIRES
TIGHTEN E BRAKE CABLE
REPLACE AIR FILTER
REPLACE FUEL FILTER
REPLACE SPARK PLUGS
TRANSMISSION FLUID REPLACEMENT
RADIATOR FLUSH
REPLACE PCV VALVE
FLUSH & CHANGE DIFFERENTIAL FLUID
REPLACE TRANSFER CASE OIL
LUBRICATE 4 WHEEL DRIVE SYSTEM
FLUSH & CHANGE BRAKE FLUID
CHECK BRAKES
HEAT SHIELD RATTLE
dR
LinkBack URL
About LinkBacks
