Results 1 to 3 of 3
This is a discussion on 20w50 Too thick? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; In my old school MR2 (87), i used to run Castrol GTX 20w50 and had no problems with it. I ...
    Registered User XenoMorph2049's Avatar
    Nov 2003
    Niceville
    20w50 Too thick?
    In my old school MR2 (87), i used to run Castrol GTX 20w50 and had no problems with it. I live in Florida in the panhandle. Winter temperatures rarely go down below 20 deg. I was wondering if the 20w50 would be too thick for the winter, or if i should change it to a lower weight in the "cooler" months. If so, what weight would be suggested?
    You shut your MOUTH when you're talkin to me!
    Registered User paragonwrx's Avatar
    Sep 2003
    Downers Grove, IL
    Do a search for oil. Off the cuff I think that does seem heavy personally. Even in the summer here ( IL ) I tend to use 10W, they cover the topic and there is a wide range based on location, but do a search and you'll find some good info.
    Para
    Nov 2003
    Niceville
    When i did the search, before posting this thread, i couldnt find anything on anyone using/not using 20w50. I'll probably end up using 10w40 anyway, and thanks for th opinion
