Best way to replace fuel filter
Results 1 to 7 of 7
This is a discussion on Best way to replace fuel filter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 1. Pull the fuel pump fuse off 2. Turn the engine on and wait until it shuts itself off automatically ...
    Registered User WRXreX's Avatar
    Mar 2002
    NY
    3. Disconnect the battery
    4. Pressure is now relieved
    5. Go ahead and replace fuel filter
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    Removing the gas cap doesn't hurt either
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    i have to do this this weekend. where is it in the bay? i haven't even had a chance to look.
    i should be able to get which fuse it is in the manual.
    thanks.
    dR
    Registered User NJSubieTech's Avatar
    Nov 2001
    Hamden, CT/Teaneck, NJ
    Well, being the resident technician, I suppose I should have jumped on this one a little sooner. Ok The fuel filter is located in the upper right corner of the engine bay, right next to the washer fluid tank. Its held in place with a little tention clamp on its side. Remove it from the clamp, and take care not to drop the little rubber ring thats around it - youll need to reuse it. I usually use place a pliers on the fuel line itself where its over the filter, and rock it back and forth to loosen it. Then take the open end of an 11mm combination wrench and use it to pry the hose off of the filter. Just keep your face away from the hose when you pry it off - sometimes there will still be pressure in the fuel rail, and it can spray gas at you.
    Opening the gas cap is usually a good idea. I dont think I would go to the trouble of running the engine without the fuel pump - Ive done several hundred fuel filters without doing that and have never had a problem.
    Speed safely,
    Joe
    merlin916@aol.com
    Aug 2001
    The Hub
    sweet, thanks NJ!!!
    dR
    Sep 2009
    Easy as anything. Just pull the fuse, with the motor running the turn it off, wire pliers work best because they dont ruin the hose. Then slip the hoses on the new one and clamp it in. 10-15 min job.
    Registered User JUSTINSNUTSWINGER's Avatar
    Jul 2008
    San Antonio
    Holy crap... this one takes the gold on bumping of an old thread.
    Giving you hell.
    N-swinger
    2000 Escort
    Maintenance schedule and poke in the eyes:
    http://www.clubwrx.net/forums/genera...nce-guide.html
