Results 1 to 7 of 7
This is a discussion on BRAKE light in dash keeps coming on within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; For a little while now when I start the car when it's cold outside the brake light in the dash ...
    Registered User wrxwookiees's Avatar
    VA
    Unhappy BRAKE light in dash keeps coming on
    For a little while now when I start the car when it's cold outside the brake light in the dash will stay on. After driving around for about 10 minutes it will go off and come back on and then stay off. Then if I accelerate quickly or make any sudden movements the brake light will pop up again.
    I was just wondering if anyone else has experienced this problem and if so what they did to remedy it. Thanks in advance!
    I also pull up my hand brake every time I park which may have something to do with this problem but I don't think it should matter.
    Thanks guys!
    -=Brian
    05 OBP WRX STi
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    Did you check the obvious?
    The master cylinder reservoir?
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    Your low on brake fluid.
    No one will truely be free until nerd persecution ends.
    VA
    Talking
    Thanks for your help! I added some brake fluid and that seems to have fixed her right up.
    -=Brian
    05 OBP WRX STi
    Registered User MidnightFLAT4's Avatar
    Sep 2003
    Dayton Ohio, Chicago IL
    ya i just noticed it today... any specifics on brake fluid? brands types? im gettin on the road tomorrow and dont want to risk problems... ill have to look in the manual
    03 MBP WRX Sedan
    STi RA gearset October 4th,STi Trans Mount
    Cobb AccessECU STG II 16.4psi. Bosal DP, Catless OEM UP, 205/55 ZR16 Futura Ultra Z's.
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    To top up just use any DOT 4 fluid. Do a search in Suspension and Handling if you want an up-rated fluid when changing out the fluid. Check the Tech. Ref. Sticky there for a list of specifications.
    C
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Sep 2003
    I bought some Valvoline brake fluid that exceeds DOT3 and 4 specs @ autozone for like 3 bucks, filled to the max line... Not only is the light staying off, but the pedal feels much more solid, and the brakes seem grabbier... I guess this is the first issue ive ever had with brakes. my subaru has been good to me, in 23000 miles and all i have done for maintanance is the following
    1.) Purolator/stock filter
    2.) Mobil 1, 5 dubya 30
    3.) I threw out the K&N filter i wasted money on, for a stocker
    4.) Adjusted tire pressure
    Ive yet to do the brakes, and im not planning on alignment until i get new rims and tires...
    03 MBP WRX Sedan
