pistons slap after i changed pistons to arias forged
Results 1 to 9 of 9
This is a discussion on pistons slap after i changed pistons to arias forged within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My engine has piston slap after i changed pistons to arias forged pistons. I can hear slap when engine is ...
    Registered User tomoking's Avatar
    May 2003
    Ostrava, Czech Republic. Europe
    My engine has piston slap after i changed pistons to arias forged pistons. I can hear slap when engine is cold and when is hot . What i have to do for repair slap ??? should i bore/hone the cylinders to bigger diameter or opisit i should get oversized pistons ???
    WRX 2002, IHI VF 34, FMIC, ...........
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    while the boxer engine is prone to piston slap in warm up conditions, it should be inaudible when the engine is warm.
    type c has done extensive research here. i would PM him for more info.
    dR
    Registered User WRXJIM's Avatar
    Jul 2003
    Powhatan VA, NYC, and NEW ZEALAND,
    keep in mind forgies make more noise than standard pistons too...
    * 1:18.47 Manfield * 11.81 @ 114.7mph *
    Tuned by
    SPEEDTECH
    PICS<---->VIDS
    May 2003
    cold and warm engine sound like diesel engine ... Can piston slap kill my engine ???
    Jul 2003
    Worse when cold... Bit you can hear the knock... Not enough of a knock to make you cringe... (if that makes sense)
    Is your engine rocking/shaking/labouring?
    How many miles do you have on it/pistons?
    If it is alot worse than when you first got it back from the engine builder I would go and see someone.
    YES piston slap is bad, but as I said forgies are usually louder than standard pistons... It will wear your bore and wreck the skirts on your piston. It is actually fairly common on Subarus. Gravity dragging the piston downwards...
    Its a tough one to guage without hearing it...
    Tuned by
    SPEEDTECH
    PICS<---->VIDS
    Registered User PlatinumWRX's Avatar
    Jul 2001
    PA
    Rob's fully forged internals were very noisy, more so when cold. As long as you got the bore within spec, it should be fine.
    Piston slap makes baby Jesus cry.
    -Jim
    May 2003
    Is your engine rocking/shaking/labouring? ........no
    How many miles do you have on it/pistons?.......800
    Nov 2003
    aus
    Running forgies(4thou ) for 2yrs now and engine is noisy.
    Forgies expand when hot and clearance is greater than OE pistons in order to run more boost.
    U ll probably have some oil consumption.Nothing to worry.
    Cheers
    Mar 2009
    Exclamation I have had this problem 2!
    i have had this problem and am working to a resolution atm. i would strongly recomend to anyone who is haveing this problem just after a rebulid not to drive or run the car. i have done aprox 800km and pulled the heads off and found scraches in the bore starting about 2-3 cm down the bore and continuing to the bottom. on oposte sides if the wrist pin. i used arias pistons. i have removed them and am mesureing them atm. its simply just not worth the risk. to see my progress on the issue please visit
    forums.nasioc.com/forums/showthread.php?p=25856247#post25856247
    I hope this helps Paul
