Clutch shudder TSB number
enjoy your new clutch.
dR
This is a discussion on clutch Chatters @ 30k miles within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My wrx has 30,000 miles and the clutch is chattering badly. It only happens during the first 10 minutes I ...
My wrx has 30,000 miles and the clutch is chattering badly. It only happens during the first 10 minutes I drive the car each day. It's VERY noticable during a first to second shift and still is noticable during second to third. What do you think is happening? Is this covered under factory warranty?
dR
Haha yeah right. It's not that easy. I've got the worst clutch "judder" ever, and I've taken my car to the dealer, TSB in hand, four times to get it fixed. The last time they removed the clutch for inspection, and still didn't replace it. Not only does my clutch "judder", but the engagement point is inconsistent, and lately I've had almost no pedal resistance until I've driven for 15 minutes. Yea!!!![]()
Matt
WRX-less, now RSX-y!!!
Wow, they replaced mine like they owed it to me. Some dealers suck bigtime.
-joe
'02 WRB Sedan
Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
Who's your dealer, and would they care about my mods?
Matt
Flemington, and they are known to be pretty mod friendly.
-joe
'02 WRB Sedan
i'm at 47K miles. will this thing still be valid? or only if you are under warranty?
dR
I doubt that it would still be valid if your powertrain warranty is over. After all, the TSB is simply a suggestion for the dealer.
Matt
