Driving without heat shield
Results 1 to 13 of 13
This is a discussion on Driving without heat shield within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; How bad is it to drive your car without your heat shield installed? I ask because my new DP doesn't ...
    Registered User Blue2004WRX's Avatar
    Jul 2003
    Syracuse NY
    How bad is it to drive your car without your heat shield installed? I ask because my new DP doesn't have the same brackets for the heat shield that the stock one had.
    --2004 WRB WRX--
    Still way too stock.
    Originally posted by MidnightFLAT4
    I like A/C for the sole reason that it makes the idle sound meaner.
    Jul 2003
    KC, MO
    hmmm so I had this same problem
    I did a search for heatsheild and read about 20 posts on the exactly same subject you did. *hint* search!
    but in a nutshell, you can trim your OEM heatshield to make it fit on your downpipe.
    The people who did trim and reinstall their heatshields said you have to do it to prevent heat going onto intercooler
    the people who did not reinstlal the heatsheild said it doesn't matter.
    I'm gonna put my back on soon.
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
    Jul 2003
    Syracuse NY
    The problem isn't size, its that my new DP doesn't have the brackets to hold the shield. I have nowhere to bolt the shield!
    --2004 WRB WRX--
    Jul 2003
    KC, MO
    hmmm my heat sheild bolts onto this bracket that attaches to the bolts that hold the downpipe on. You can just use the three screws on this bracket and not worry about putting the other screws that used to attach to the old downpipe on.
    Jul 2003
    KC, MO
    Jul 2003
    Syracuse NY
    The brackets to hold my heat shield were WELDED to my old DP..... they aren't removable.
    --2004 WRB WRX--
    Jul 2003
    KC, MO
    are you sure? I got a 04 WRX too and the bracket attaches on the turbo/downpipe bolts just like every other WRX.
    Jul 2003
    Syracuse NY
    I'll double check but my mechanic said that, it looked like that; I do have 2 brackets that were taken off, but neither of them seem to fit the heat shield.
    -Blue
    --2004 WRB WRX--
    Jul 2003
    KC, MO
    ok I bet one of those was the heatsheild bracket.
    If I had a digi camera I would take a picture
    you can easily reinstall it. Just take off the top two bolts from the
    downpipe/turbo connection, fit the bracket on, then put the bolts back on. then you can mount the heat shield again.
    Jul 2003
    Syracuse NY
    Thanks, I'll try that.
    BTW, don't buy an HKS SSQV
    Get a GFB HYBRID!
    --2004 WRB WRX--
    Philly
    I made my own with thermo-tec cool-it mat. It's more of an insulator I guess, but it works very well. I blocked off the turbo all the way down to the tranny, basically like making a wall dividing the intercooler from everything else. Extremely light weight, mine's only held up by aluminum foil ducting tape. Cool-it mat in a 24" x 48" size costs $26 from summitracing, you'll use about 1/4 - 1/2 of it depending on if you want to double up the layers. The leftover you can use to wrap sensor wires, A/C piping, etc. I think I have some old pictures up on my yahoo page. The one in those pictures was my first one, I've since added a second layer because I had enough left over after doing everything else I wanted to under the hood.
    Jul 2003
    KC, MO
    is the GFB hybrid 50/50?
    Get a GFB HYBRID!
    Jul 2003
    Syracuse NY
    Both, which is a great design. It comes 50/50, so you can hook it up to your return hose, or you can use the blanking cap they provide to make it %100. I keep mine 50/50... quiet when I'm just putting around, but anything over 4,000 RPM and you get a sick sound.
    -Blue
    --2004 WRB WRX--
