Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
This is a discussion on Synthetic Engine Oil within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; yeah turbos are rough on oil, but synthetic oil can take it....and when you consider that truck drivers go up ...
    Mar 2002
    Calmer than you are
    yeah turbos are rough on oil, but synthetic oil can take it....and when you consider that truck drivers go up to 100K on synthetic oil you have to remember that ALL diesel tractors have turbos.
  2. #17
    Registered User ScoobySteve's Avatar
    NorCal
    Question Which Grade of Oil
    Sorry to dredge up this old thread again, guys; but my search didn't give me exactly what I was seeking.
    Coming up on the 7500 miles. I'm going to switch over to Mobil 1.
    Here's my question. Which viscosity ? 5w30 seems to be standard, but the manual gives other grades which can be used for high temperatures, extreme conditions. I've heard others who recommend 15w50 for a turbo.
    Most of my driving is a long freeway commute But I do engage in some spirited backroads driving on the weekends and I have a track day coming up at Thunderhill next week. I expect it'll be hot and I'll be working the car hard with plenty of high RPM running. Would something like 10w40 be a reasonable compromise or am I fine sticking with 5w30 ?
    Old, but not slow.
  3. #18
    Registered User SACTOWNREXMAN's Avatar
    Aug 2001
    Elk Grove, CA USA
    Ya man, but diesel trucks also use some ungodly amount of OIL. The more oil in your sump, theoreticaly, the longer it should last. I remember that our Kenworth use to use something like 20qts!
    I know that in AUS. One of the popular modifications is to go with a 7 or 8 quart sump (Oil pan).
    Andy
  4. #19
    MisterX's Avatar
    May 2002
    Prague, Czech Republic
    Porsche requires synthetic oil.
  5. #20
    Registered User pace's Avatar
    Sep 2001
    Brook Forest, Colorado
    I would go with 5W30, or 10W30 if it's really hot and if your next oil change will occur before winter, at which point you will want to switch back to 5W30. I've heard of folks running 0W30, but I haven't personally done so. Everybody has a theory on what works best, but so long as you run a good quality synthetic oil you should be fine with whatever weights the owner's manual specifies.
    -Pace
  6. #21
    i've been told to use conventional oil for the first 12-15K miles....that's 15,000 not 1500. The synthetic oil works so well that if you start using it too soon the motor doesn't get a chance to break in properly. the manual says the break-in period is 4500 miles, but that's just the "danger" time when you can really hurt something if you overtax the motor...it continues to settle in untill about 12,000 miles. After that you can switch to synthetic and keep the OIL in for quite some time, however the same cannot be said for the FILTER. ALthough synthetic oil can go upwards of 15000 miles (heck truck drivers go as much as 100K miles on synthetic) the filter still has to be replaced every 3-4k miles. e-z lube will change your filter and top off the oil for you and it costs MUCH less than an oil change (top-offs are free for 3k miles and the filter's like $5).
  7. #22
    oil change
    Don't worry about changing your oil to soon i changed mine at 600 miles and switched to mobil 1 5-30 it's running great if you heard and engine needs 4000 miles to break in that's a big lie from what i heard from mechanics that i know.And as far as changing oil 5000 to 10000 should be the norm.
  8. #23
    Registered User strohausii's Avatar
    Aug 2002
    near Boston
    re: motor oil,
    I'm looking to get mobil 1 10w40 (50 is too thick), i'll post any diffs I find (startup/ slow to rev). If heavily modded, special order the f1 standard, mobil1 "motorsport" is a 50 weight.
    re: break-in...well, everyone has something to say about today's breakin processes, but just to let you know, there have been disections of first change oil filters with a quarter's size of metal shavings. Parts may be made to better tolerances today, but mating surfaces should be allowed to "settle"in with each other.
    From the years of car mag. reading, i've seen a couple of articles of unmodded vehicles gaining speed as the engine "loosens up".
  9. #24
    Auburn, WA
    Amsoil 1030 Turbo Formula every 2000! Heck if ya buy a bunch the more you can change your oil!
    95' Eclipse GST
    FP green
    720's
    02' WRX
    TurboXS Stage 2 w/Blitz SUS
