How sturdy are the side jack points? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on How sturdy are the side jack points? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally posted by Retro Actually, could someone post a pic. of the rear dif, and draw an x (not arrows) ...
    cnk
    cnk is offline
    NJ
    Actually, could someone post a pic. of the rear dif, and draw an x (not arrows) exactly where the jack would go? It's silly, but I don't trust jacking it up anywhere now.
    You don't really need a pic. . just put a piece of wood directly under the rear diff and then the jack under the wood. You don't want to put the jack directly in contact with the diff.
    Calvin
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Re: How sturdy are the side jack points?
    Originally posted by WRB04WRX
    More specifically, how do they stand up to hydraulic floor jacks? Every time I've jacked a car up using the side jack points resulted in damage (bending) of the jack point when I didn't use the provided (emergency) jack. Also do the sideskirts take any abuse?
    Just a question that crossed my mind. I'm a new 04 WRX owner.
    Mine too..
    I now use a round block of would inserted to fit inside of my floor jack that helps cushion the metal.
    Shotgun
    Registered User Retro's Avatar
    May 2002
    USA, FL
    Originally posted by cnk
    Go here for side sill adapters: http://www.protechproducts.net/images/JACKPADS.asp
    Calvin
    Happy, happy, joy, joy!
    clutch, shift, gas, clutch, shift, gas, shift, clutch, gas, clutch gas, shift... oops!
  6. #19
    Nov 2002
    Ky
    Originally posted by Chunks
    Oh thank god. I was jacking up my car to change oil and I was using the manual jack points, my jack is different than the emergency and a lil more heavy duty and i felt like my sideskirts were going to be ruined afterwards.
    Chunks,
    Run up to Wal-:Mart and get some "RhinoRamps" they are heavy duty plastic ramps that will get your car up PLENTY high for around $29 bucks and you can drive right up on em and do dam near everything under the front!!
    (oil changes,pokin around on ****,etc)
    Best $29 I have spent so far
    .02
    Shotgun
    ps,or the rear can be raised the same way
    (Always use wheel chocks and E-Brake too)
  7. #20
    Nov 2002
    Ky
    It really is quite easy....
    Just slide your roll jack under the CENTER of the diff. parallel with the axles and have at it!
    just jack slow to make sure it,s not gonna slip (it wont, but Im carful around ANY jack)
    Shotgun
  8. #21
    May 2002
    USA, FL
    Don't you mean Perpendicular to the axles? Parallel means side by side, so I would be jacking along the ground.
  9. #22
    Nov 2002
    Ky
    Oops!........
    Senility settin in early...<g>
    yea, What cha said.
    Shotgun
