Replacing Fuel Filter
Results 1 to 7 of 7
This is a discussion on Replacing Fuel Filter within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Ill try this again with a more understandable subject... I am a fairly competent mechanic I work on 40million dollar ...
    Feb 2003
    Wichita Falls TX
    I am a fairly competent mechanic I work on 40million dollar Aircraft for a living so if it is to much to ask for instructions then just point me to the fuel filter (as I am not a car mechanic) and I can figure out the rest
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Is this an '02 WRX? That's the only model I'm intimately familiar...
    This is the fuel filter. It's located on the driver's side of the engine compartment.
    You'll need to vent pressure in the fuel lines before cracking the lines open. (Normal shadetree procedure is to open the gas cap on the vehicle and let sit for a considerable amount of time and make sure you have a shop rag/towel to catch any spilling fuel).
    You'll also need to disconnect the fuel lines from the unit. The hose clamps are small and can't take a lot of abuse so the recommended torque on them is ~1 lb/ft when tightening upon re-install.
    That should be it!
    P.S. The unit is black in color on my vehicle.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Jun 2002
    Honolulu, HI
    Also note that the schedule 1 maintenance on these is replacement every 30k miles...
    Aloha, Richard...
    Retired Moderator
    Feb 2003
    Wichita Falls TX
    Thanks for your help. The picture was an added bonus
    Jun 2002
    Honolulu, HI
    No problem.
    Aloha, Richard...
    Retired Moderator
    Registered User lpdolci's Avatar
    Aug 2001
    New York
    Do you know which fuse controls the fuel pump? The manual does not say.
    Jul 2001
    Western NY
    One way is to disconnect the fuel pump relay. It's behind the passenger-side kick panel.
    2002 WRB 5-spd: K&N drop-in, silencer hack, Samco IC hoses, Godspeed uppipe, Bosal downpipe w/stock 3rd cat, Tanabe RM catback, TB Racing crank pulley, Tanabe GF-210 springs, Koni Sport strut inserts, Group N tranny & motor mounts, Whiteline rack bushings, Kartboy rear-sway endlinks & shifter, Goodridge ss brakelines, Akebono ProACT front pads
