Page 1 of 13 1234567891011 ... LastLast
Results 1 to 15 of 185
This is a discussion on Oil Change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Excellent link for the inexperienced: http://www.machinerylubrication.com/...?articleid=443...
    Registered User Ah Clem's Avatar
    Jun 2002
    Maple Street
    Automotive Oil Changes Made Easy
    "The tools of conquest do not necessarily come with bombs and explosions and fallout. There are weapons that are simply thoughts... attitudes... prejudices. To be found only in the minds of men. For the record, prejudices can kill, and suspicion can destroy, and the thoughtless, frightened search for a scapegoat has a fallout all its own for the children, and the children yet unborn. And the pity of it is that these things cannot be confined to The Twilight Zone."
    Best Regards,
    Ah Clem
    Registered User WRXin''s Avatar
    Jun 2002
    Houston, TX
    Oil Change
    I use Mobil One Super Synth 10W- 30. I'm sure many of you do as well. I was wondering if those of you who use the same oil change it every 3,000 miles, or if you pass that mark by a bit...by bit I mean somewhere between 500 - 1,000 miles. Thanks in advance
    Fahd
    Floats like a butterfly and stings like when I pee!
    Registered User RLsChMiDt's Avatar
    Dec 2002
    Cleveland, Ohio
    I'd say it really doesn't matter...
    If you drive the car hard a lot, then change it at 3000, it's prolly good in the long run.
    If you don't drive the car too hard, then you can afford to wait...
    Take this for what it's worth. I change mine every 3200 er so, because I like to have fresh oil in.
    -Ryan |Dub-Yuh Our Ex Ess Tee Eye| My Car
    Jun 2002
    Houston, TX
    Yeah, I was figuring that if I go every 3,500 miles then I should be okay. I drive a lot...not necessarily hard...just a lot. So the 3,000 miles comes quick for me, and it's kind of a hassle to change the oil at such short time -- not distance -- intervals.
    Fahd
    Registered User blackshadow's Avatar
    Apr 2002
    Milan, Italy & Arnhem, Netherlands
    I change mine every 5000 miles. I use the exact same oil as you.
    autobahn storming scooby
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I also use the same exact oil you use (Mobil 1 10-30W) and I change my oil every 3000 miles, give or take a couple of hundred extra. I really do beat the hell out of my car on a daily basis, so there is no reason why I don't give my pride and joy a new blood transfusion every 3000 miles. She deserves it.
    Jun 2002
    Houston, TX
    Wow...how does the oil look when you change it after so many miles?
    Fahd
    Apr 2002
    It's dark, but i wouldn't say that it's significantly darker than at 3000 miles. The only part I worry about is the filter. I believe this has been discussed before though...
    Apr 2002
    also to clarify, the oil "feels" clean, and i don't think it has broken down in a way that would risk damage or performance loss in any way. I definently care for my car. Mobil one synthetic really is good enough that i trust it for 5k miles. Unless someone can prove to me otherwise.
    Not changing at 3K mi is not a matter of "missing the mark," as there simply is no mark. None. To maintain your warranty in case of a motor failure you ought to follow Subie's interval and grade rec's, but other than that, the only way to know if it's time to change oil is to do oil analysis. The lab will let you know how the oil is holding up, and whether you've got elevated insolubles in there etc.. It's a matter of sampling 100 ml or so from the middle of a slow drain, sending it in with a check, and getting the news in the mail to find out, but I concede it's a huge hassle at times and I presonally don't like doing this. Cost is about as much as a full synth oil change.
    Dark oil isn't good or bad; for every person that says "the oil is black, it must need changing" there's another that - like me - *likes* dark oil, b/c I believe that if it's dark, it's got nasties in solution, which is one reason I put it in the motor in the first place. I too use M1 10W-30, since M1 doesn't come in a 10W-40 that I'd prefer and the fantastic M1 0W-40 is not a permissible range according to our manuals in the US. M1 is on the thin side of the xW-30 range, and I don't know how well it'll hold up with typical use in my climate (southern CA USA), but I'll just have to find out.
    I won't accept intervals shorter than 4K at this point, as there's no reason for a road car to use synth oil at a faster pace in the 21st century IMO. I plan to run this first lot of M1 for 3750 like the "good book" says, then increase the drain interval as I get an idea of what's going on. The first change isn't going to be meaningful data-wise, since the motor is still newer and the synth is diluted with some remnants of dealer dino juice. As I go a couple more drains, that'll no longer be an issue. We'll see...
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    i change every 5K w/ mobil 1 - 5 weight. i exclusively use wix filters.
    dR
    Jun 2002
    Houston, TX
    You know, I was reading your post, and was thinkng, "wow this dude really knows his stuff." But then I read your signature, and thought, "oh crap!"
    J/K Thanks for the info
    Fahd
    You're quite welcome, and thanks for noticing my .sig... Now that I think of it one question that comes to my mind is what kind of consumption people are seeing, if any, with 5W-30 or 10W-30 M1. I'm hoping the 10W stuff I'm using will keep use at a minimum, and will let you guys know if anything outrageous happens. Good thread!
    SD
    Apr 2002
    I use very little oil. I haven't had to add oil at any point other than oil changes. Then again i only have 15k miles so the engine is in a pretty sweet spot right now.
    Great. I used ~300 ml in 3K miles once, but that was dino juice and probably 5W-30 since the dealer put this in. I have to wonder about M1 since it is on the thin side, but it's truly great oil so I'm hoping top-offs will be minimal with 10W-30 M1. I know LS1 folks spike it with some 15W-50 to help with their consumption, but I don't think we'll need to do this and your experience is very positive. Thanks!
    SD
