Oil Plug Gasket? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Oil Plug Gasket? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am about to change my new 03WRX oil and oil filter, but I found out that it is a ...
    Registered User WRXGO's Avatar
    Apr 2003
    WA
    Cool Oil Drain Plug
    I am about to change my new 03WRX oil and oil filter, but I found out that it is a little different than my previous Prelude. First, what is the electrical wire look alike that connects to the oil drain plug?? It is a white color wire. Second, what is the O Ring some people have mentioned in the oil filter part? And Do I need to replace the O ring for the new oil filter? Thank you for the help!
    WRXGO
    Registered User mesaro's Avatar
    Oct 2002
    MD
    The white wire that connects to the drain plug is prolly the oil temp probe. Do you have the OEM guages? Also the "O ring" everyone is talking about is the crush washer that goes on the plug as well. Some people change it everytime, others wait even until the 10th oil change to change it. You can try to reuse it, but if you see a leak, change it.
    Good luck with the oil change!
    2005 Forrester XT premium
    Registered User Carl AMG's Avatar
    Jan 2003
    Fairfax, VA
    Re: Oil Drain Plug
    WRXGO
    My '03 doesn't have any wire connected to the drain plug. Are you sure you're actually looking at the drain plug?
    2003 Subaru WRX Sedan 5 spd.
    Platinum Silver, TurboXS Stage 3 and lots of other goodies. See profile.
    2002 Mercedes Benz C32 AMG
    2005 Lotus Elise on order
  6. #19
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Re: Oil Drain Plug
    WRXGO
    The rubber O-ring for the filter is built into the filter - so you do change it every time but it isn't a seperate part.
    The crush washers are like $.35 a piece. I buy them by the dozen and change it every time. It's a good idea.
    That wire is for the oil temp probe and won't be present if you don't have an oil temp gauge.
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
  7. #20
    Apr 2003
    WA
    Oil Drain Plug
    Thanks for the info. GV27 Indeed, the white wire that connects to the drain plug is for the oil temp gauage. After going through three different auto stores to look for the oil washer, I went back to the dealer to buy it. I bought a lot for future oil change. It is funny that not many auto stores carry WRX oil washer.
    WRX GOOOOO
  8. #21
    Jul 2001
    Western NY
    Magnetic?
    Hi. Are any of these drain bolts magnetized? Know where one can be had??
    2002 WRB 5-spd: K&N drop-in, silencer hack, Samco IC hoses, Godspeed uppipe, Bosal downpipe w/stock 3rd cat, Tanabe RM catback, TB Racing crank pulley, Tanabe GF-210 springs, Koni Sport strut inserts, Group N tranny & motor mounts, Whiteline rack bushings, Kartboy rear-sway endlinks & shifter, Goodridge ss brakelines, Akebono ProACT front pads
  9. #22
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I have had my fumotovalve for almost a year now on my car, and I would never change it back to stock. I also got the model with the nipple, that allows you to connect a piece of tubing to the valve, so you can aim the outflowing oil better. Cut my oil change times in half. I recommend getting one.
  10. #23
    Aug 2001
    Houston, Texas
    Just about all subarus ever made use a 20mm oil drain plug and washer. A 20 mm fiber washer installed at 40 ft.-lbs. should work fine. Pep Boys sells the drain plug and washer as a set for $2.79 or you can buy washers alone. Manufacturer name is Oil-Tite.
    Mark
    02 WRX Wagon
  11. #24
    Jun 2002
    Re: Magnetic?
    http://www.magneticdrainplugs.com/metric.htm#1011M
    20mm-1.5
    1993 Honda CBR600F2
  12. #25
    Jun 2004
    NE Washington State
    Fumoto
    I bought the standard fumoto valve. It went on easy and works great. I have an 04 STi and the fumoto does not stick out more than maybe 1/2" more than the stock one. Since its at about a 45 degree angle that means it is just shy of flush with the bottom of the pan by my reckoning.
    If you have an STi, I would get a nippled version, so you can start draining the oil via a tube while you take off the plastic engine guard. This will drop your change time by a few minutes at least, since you have to remove the guard if you want to get at the filter with minimum mess. I think the nippled version is like $3 more. With shipping and everything I paid 28 and change for that standard version.
    KH
    Scoobys Rule.
    No matter what you do to it, its still a civic.
    Drag racing a civic is like competing in the special olympics. Even if you do win, you are still retarded.
  13. #26
    Registered User Prince Ali's Avatar
    May 2002
    Southern California
    Re: Fumoto
    KH
    I just cut a square out of the plastic guard, just below the filter. I didn't want to take it off every time I change oil.
    Thanks,
    Ali
