Results 1 to 15 of 16
This is a discussion on Oil Overfill within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Doh...I moronically added 5.9 gallons vice the correct 4.9 gallons (ive changed the oil like 6 times already...youd think that ...
    Feb 2002
    New Jersey
    Red face Oil Overfill
    Doh...I moronically added 5.9 gallons vice the correct 4.9 gallons (ive changed the oil like 6 times already...youd think that I would have it down) during this last oil change...so I definitely overfilled the oil. Are there any reprecussions to this at all? What is the oil pressure sensor used for? Does this sensor only measure low oil pressure, or will it reciprocate for high pressure as well?
    A separate question...can you flush the coolant without lifting the car? Approximately where is the release cap under the car?
    Thanks guys....
    Feb 2002
    New Jersey
    HAHA...ok I must really be losing it...
    QUARTS not GALLONS..LOL
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Overfilling the engine oil can cause just as many problems as underfilling! Would you add a quart if you had only put in 3.9?
    You can frothing, viscosity breakdown due to aeration, etc.
    DEFINITELY drain the excess and get the right level!
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Also, the oil pressure can get high enough to squeeze oil out of the main seals and PCV valve.
    Save yourself some grief and drain the excess oil out.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Feb 2002
    New Jersey
    How do you suppose I drain some of the oil out without draining it all?
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    yep....i'm pretty sure though that you'd notice it was overflowing if you were putting 4.9 GALLONS of oil in there
    Silver 911
    WRX's older brother
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Loosen the plug until the oil starts to run out around the plug, without removing the plug all the way. Tighten it up when you have let enough out. It's messy, but it's easier than pulling it all the way out, catching the oil, and pouring it back in.
    Registered User LostLamb's Avatar
    Aug 2002
    NorCAL
    Some cars will tolerate the extra oil.
    For instance, BMW M50, M52, M54 engines can tolerate extra quart of oil. In fact, it's the recommended solution to the value ticking. When under extreme G's (read extreme driving), not enough oil is sent to the attenuators, and thus the values starts ticking. Adding an additional quart of oil resolves that issue.
    Older cars will not tolerate additional oil, as mentioned above, you'll get frothing, crank drag, etc. Frothing is the worse, as it prevents a your from getting a constant oil pressure. Which results in engine shut down.
    A boxer engine like the WRX should tolerate .5 quarts extra. Sorry, I don't know if the WRX has variable valve timing, and if it does, it should tolerate the additional oil.
    I purchased a top-side oil changer from Groit's Garage, and it's wonderful for changing oil and sucking up excessive oil. I no longer have to get underneath my car for oil changes. The oil filter on my car is a canister type.
    -LostLamb
    Uh guys? After I read this post I went out to take a look at my WRX. There seems to be some bird poop on the drivers side A-pillar and almost all of the windshield washer fluid is gone. Should I trade it in for a Ford ZX2 or just light in on fire?
    God I miss my rex. -Koyokid
    Rest in peace Koyokid.
    Aug 2002
    NorCAL
    Most radiators will have a drain underneath and on the corners. You won't have to lift your car, just poke your head underneath and look for the drain plug. Unscrew it and drain the coolant into a catch bucket. Don't drain it into the street!!! It's illegal in most states.
    Have fun.
    LostLamb
    Feb 2002
    New Jersey
    Ok thanks all....I plan to drain off some of the oil this evening. I figured that I would have to do so. I'll loosen the drain plug and let it run out for a bit. I hope I get a decent seal when I tighten it back up however, which is my number one concern. Ive only driven about 250 miles in this state, so I should be ok. For now, would loosening the oil cap reduce the pressure at all until I can get out in the pouring rain tonight and drain some of this oil?
    Just for my own info, what is frothing and crank drag? Thanks again.
    Aug 2002
    NorCAL
    Driving around with your oil cap loose is not a good idea. It's not the pressure that is detrimental, it's the excessive oil in the crank case.
    Frothing, think of a latte with foamed milk. That foam milk can be your oil if you have too much oil in the crank case.
    Crank drag, each time the crank rotates and hits the oil, there's excessive drag on it because of too much oil. Oil is viscous, and it will add some drag to the crank moving inside your case.
    The worse is frothing which prevents your oil pump from working correctly, and starving the engine of oil. Think of it this way, would you like to suck foam milk from a straw or cold milk from a straw?
    You'll get a good seal when you tighten it. Remember because you have oil on the bolt, you might want to check it after driving your car for 100miles. Make sure it's nice and tight. Don't need it loosening and then dropping out. It won't happen, but just in case.
    Feb 2002
    New Jersey
    Thanks LostLamb...excellent responses. Will the sensor detect if the pressure does get too high...or is the proessure sensor only triggered by low pressure?
    Aug 2002
    NorCAL
    A standard oil light in cars nowadays only detects low oil pressure. You would have to get a oil pressure gauge to determine whether or not your oil pressure is within normal operating specs.
    -LostLamb
    Registered User SobeWRX's Avatar
    Mar 2002
    Reykjavík iceland
    before the wrx i had an RX-7. got lazy took it to the jiffy lube for a quick oil change. dude apparently gave me way to much oil, blew a couple of the high pressure oil hoses lose. sprayed oil all over the under carrage and nearly gave me a heart attack....
    extra oil not good
    i will never set foot in another jiffy lube...
    Feb 2002
    New Jersey
    Ehh..i drained the oil until it got dark out...I doubt I drained enough (as it was trickling and i FEAR undoing the drain plug and sticking it back in after 3 seconds.). I am using full synth...I suppose all of these problems will still occur with this type of oil? I can't imagine sythetic oil, the most corrosive and vile liquid known to man, frothing up...hah. I probably got about .5 quarts out of there.
