BG MOA/ MOC safe with synthetic?
Results 1 to 8 of 8
This is a discussion on BG MOA/ MOC safe with synthetic? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Is it O.K. to add the BG MOA or BG MOC to an engine around is 30K service even if ...
    Aug 2002
    Is it O.K. to add the BG MOA or BG MOC to an engine around is 30K service even if I'm using synthetic oil? I understand that if I can find the BG MOC, I only keep it in and drive around for 15 minutes or so before draining, but iis it safe to use with synthetic? Also, What is the difference between the MOA and MOC....cause I have only seen the Motor Oil Additive.... Thanks
    Sedona Red Wagon, Nicely Tinted
    Thule Bike RackS
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    I don't see MOC on the website www.bgprod.com
    I know with the MOA, they had offered a roadside assistance plan with the MOA. Whether it's still in effect, I'm not sure.
    You should be fine using good oil and consistent oil changes.
    Aug 2002
    Thanks Tan. I can recall reading a post by GV27 where he recommended an oil "cleaner" of some sort when doing the 30K service, then draining it when changing fluids. I'll try to find the link, but the cleaner was Wwhat I was wondering about.....wqhat it does, is it necessary, etc.
    Thule Bike RackS
    Aug 2002
    oh crud...I think I'm just confused.....
    lemme look again
    Thule Bike RackS
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    if you're talking about oil flushing....they are petroleum distillates. Many people back in the day used 1 quart of kerosene or diesel fuel in the crankcase. Let it idle for 5 minutes, then do the oil change.
    Aug 2002
    Yep. My bad...Just saw GV rec'd BG quick clean.....So I'll probably pick that up with a can of BG44K also. Thanks for the help, Tan.
    Another quick question- Do the tranny and rear diff use the same oil? I.E., Motul Gear 300 or Gearbox, or their Dexron III technosythese ?
    Thule Bike RackS
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    run a quick search...
    IIRC, they use a 75w90 GL-5 gear oil.
    Aug 2002
    I've read soooooo much through the searches, I wanted to ask one myself I think I read somewhere about the dexron....so i'll check for that. Thanks again Tan
    Thule Bike RackS
