Results 1 to 4 of 4
This is a discussion on Question about a CEL within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey I just got my wrx 28 days ago, and I have just eclipsed the 1000 mile mark, and am ...
    Dec 2002
    Hey I just got my wrx 28 days ago, and I have just eclipsed the 1000 mile mark, and am at 1080 when a check engine light comes on. I went back and retightened the gas cap and everything, and I have been reading other posts about cel problems and I was just wondering if you guys think I should just let it go for a week and see if the cel shuts off, or should I go to the dealership right away? Thank you for your help
    Registered User racerWRX's Avatar
    Jun 2002
    steeltown
    call the dealer...you shouldnt have got a cel yet (as long as she is not mod'd )
    if you are runn'g stock there is a factory glitch somewhere . im sure its nothing just call and get them to clear the cel
    have you ever been 4 bagged ???
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    I'm pretty sure the WRX's ECU wont reset the CEL even if the condition that caused it no longer exists. Therefore you either have to get the code pulled and cleared or reset your ECU by diconnecting the battery.
    Most autzones will at least pull the code so you know what it is. But someone said that they changed their policy and no longer do that. The only problem with resetting you ECU yourself is that you will get bad mileage and performance for about a tank of gas.
    If you plan on modding your WRX a code scanner might be worthwhile. I get a CEL here and there and all of them have been nothing to worry about (loose gas cap, catalyst inefficiency, etc ... )
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
    Registered User RexMobbin''s Avatar
    Nov 2002
    zipity here, zipity there, i'm zipity everywhere...
    where do you get a code scanner and how do they work? how do you use them?
