lug nuts can be torqued to 75 lbs. just tightened mine this past weekend after the silencer removal
o-|-<) bryan
This is a discussion on torque specs within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; did a search, couldn't find it. a little while ago i remember a thread that told almost every torque spec ...
did a search, couldn't find it. a little while ago i remember a thread that told almost every torque spec for many of the more common "tinkering" nuts/bolts. can anyone find this thread (moderators)? especially for the lug nuts torquing.
o-|-<) bryan
-2003 Blue WRX, complete 2007 STi Engine/Drivetrain transplant - Pic 1 | Pic 2 | Pic 3 | Pic 4 (new!)
-1994 Black Supra TT 6MT - Pic | Build/Restoration Thread: 67mm, Fuel, Painted Engine Bay, Fuse Box Relocation, Wire Tuck, etc.
www.TriStateTuners.com
i torque mine to 72lbs each and every time...
have fun!
Jamie
You all actually break out a torque rench for the lugs? Damn... I just turn mine on tight and call it a day.
"Does this look like a Q to you?"
<swivles hips>
"How bout now?"
Giggidy Giggidy Giggidy!
yah, i used to just wrench them on, then one day when driving home in my Ac CL, one popped off (either over or under tightened), causing two others to pop off, i barely made it off the freeway. that was pretty spooky. thanks guys.
yeah and improperly torqued nuts can cause you brake to warp easier, or if tey are cranked down so tight with an impact you cant get em off when you get a flat.(and your a wuss)![]()
