Results 1 to 15 of 28
This is a discussion on Oil Change help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Today, in the blistery cold weather I performed my 1st oil change to my 2002 WRX. I had scheduled with ...
    Registered User WReXnFX's Avatar
    Queens, NYC
    1st 3000 mile oil change story
    I had scheduled with the dealer twice and they kept giving me 2 week later dates.
    I was running 3204 miles and really need to get the oil change.
    After reading countless oil change threads.. basically this is what I did..
    The oil filter was really really tight. I don't know how the hell they get it locked in that tight. I guess it's a virgin.
    I tried those Craftman rubber locking tool, no good. The filter was too short and not enough room to get torque..
    Then I read some thread where people just stuck a screwdriver thru the filter and was able to loosen it. That didn't work because the OEM filter is made of metal and you have to be real strong to do it. I did bang it a few times and left couple of dents but no holes.
    So I had enough.. I jacked up the driver side just 4-5 inches.. then took the power drill and drilled a big hole, my drill bit got stuck in it. Then oil began to leak out. I couldn't take the drill bit out, so I figured, hey why not.. I just used the stuck drill bit and use it to turn and loosened the oil filter. I did it like popping a good bottle of red wine and yes.. the oil leaking out looks like red wine, burgandy.
    Took the Bosch Premium Grade filter lubed it with some motor and 4.5 bottles of the good Mobil Regular 5w-30 oil.
    BTW, the drain plug was also darn tight but a couple of shots of silicone lubricant loosened it. I guess the cold weather kept it locked in. (Temperature was around 21 degrees)
    Warmed up the car for 5 mins, crawled under to make sure there are no leaks and drove her around a bit..
    02' WRX
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    Wow, sounds like you had quite the arctic ordeal! I'm always complaining about it being too hot and/or too sunny when I'm working on my car. I guess I'll shut up now.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Registered User RexMobbin''s Avatar
    Nov 2002
    zipity here, zipity there, i'm zipity everywhere...
    when i changed my oil for the first time (400 miles...overly cautious? you be the judge) i was helllllla baked, and hadn't smoked in a REALLY long time. i wasn't sure if i was even twisting the filter the right or wrong way, i had to keep re-orienting my thoughts to make sure. anyways, just a lot of twisting with a latex on for grip (she was a virgin, afterall) and i popped that cherry right off. it must have been around 25 degrees or so. god, i hate this nebraska weather...i miss Cali
    Dec 2002
    Help needed on Oil Change
    Hey guys, I went out today to do my first oil change(500 miles thank you very much ) but anyway, I get out there and locate the bolt right quick, and I am like oh yea this will be easy, heck no! The oil pan bolt is on there so dang tight, I dont know what to do. So anyone know how to loosen it to get it off, and even though I have changed oil for years, I still have to wonder, when you are loosening the bolt on the wrx, are you pulling the wrench towards you, or pushing it away from you? I cant get this off so any help would be GREATLY appreciated, Thanks Guys
    Ben
    Registered User CustomS10's Avatar
    Nov 2002
    Western Mass
    Re: Help needed on Oil Change
    Ben
    1st off i think 500 is 2 early to change oil on a brand new car. but to get it off u pull toawrd u. the car doesnt need to be jacked up. throw the ebrakw on as usual get under and lodge ur foot in front of the tire and pull. u should get it its not as hard as the oil filter. good luck on the one.
    -Ben-
    Spark it or Park it!
    Registered User MtnWRX's Avatar
    Dec 2002
    Amongst the trees & boulders
    Not sure what gorilla they have at the assembly plant on this, but he does do a heck of a job torqueing that drain plug down!! On my first oil change the bolt was really tight, also. The gasket had paint on it, so they put the drain plug in early in the process. The bolt is a standard right hand thread, just may take a lot of force to break it loose.
    The spec for the plug is 33 ft. lbs.. Be sure to put a new gasket on it. Good luck.
    Leo
    "Stupid should hurt."
    Registered User TonyMS's Avatar
    Nov 2002
    New Orleans, LA
    Just did my first oil change today at 1719miles and had the same problem of all my new cars that I have owned. I got the filter off with one of those strap wrenches (only time I ever use them is when the car is new) and got the plug off with a socket laying flat on my stomach and pull for all its worth for about 15 minutes till it broke free. I don't think the manufactures pay attention to there own instructions a states in the owners manual not to over tighten. Anyway, put the filter on hand tight and use a new washer on the drain plug and snug it up good. Off topic but kinda of funny, when I asked for a oil filter and washer from the dealership he said are you sure you want to change it yourself.
    Tony
    --Tony
    2002.5 Mazda Protege5
    1997 Mazda Miata STO Edition #774-1500 (Sold)
    2003 WRX Silver Sedan
    -STi Grill
    -STi Projectors
    -Aust Spec 17' wheels
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    BREAKER BAR
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    As far as direction, it depends on how you have the wrench oriented. So just imagine yourself under the car looking up at the bolt. Clockwise tightens, counter-clockwise loosens. Or, "righty tighty, lefty loosy". You can make a breaker bar out of a short wrench by slipping a piece of pipe over the end.
    Chris
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I post this on almost every single oil changing thread, and I just can't understand why more people don't use them. If you get sick of having to take off the oil pan bolt and going to the store to get crush washers, do what I did and buy a fumotovalve.
    http://www.fumotovalve.com
    You only need to take off the stock bolt, put on the fumotovalve on and tighten it up with the crush washer it comes with. That's it. You never have to take it all the way off ever again. Just use the spring loaded on and off lever on it. Take me 2 seconds to change my oil. And if you get the nipple version, you can put a hose to it and it will drain into any container you want. And if the container is about to overflow, just turn the lever to the off position, and get another container.
    I swear by this valve. It works so well. I could not live without it.
    Nov 2002
    Western Mass
    but any ******* can drain ur oil and leave u stranded and fooked.
    -Ben-
    Mar 2002
    San Jose, CA
    They are gonna be awful skinny to get under my front end. Plus I don't make enemies, just friends
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Speed is pretty thin
    Registered User thechickencow's Avatar
    Mar 2002
    West Allis, WI
    You guys need to work out more.
    Nov 2002
    Western Mass
    yep tan is right i am. i'll get up under ur car and steal ur mobil 1 or ur amsoil no big deal for me.
    -Ben-
