Tranny Issue
Results 1 to 7 of 7
This is a discussion on Tranny Issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have some concern with my shifter. When I start the car and shift to reverse, the shifter is a ...
    Jan 2003
    Tranny Issue
    I have some concern with my shifter. When I start the car and shift to reverse, the shifter is a little reluctant and makes a sound as if I'm grinding the gears. I always step on the clutch all the way down, so I know it's not that. Anyone else have this problem or might know of what it is.
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Mine does that a little too. Try starting it, then letting the car idle with the cluth out for a few seconds. This gets all the gears and oil moving around and it seems easier to get into reverse.
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
    Dec 2002
    Calgary, Alberta
    Reverse has no syncro, even when you depress the clutch, the tranny is still turning for a few seconds under its own momentum. The gears then clash. I usually pop mine into first before shifting to reverse, to stop the tranny gears. Works like a charm for me. Next thing is to check clutch adjustment.
    Registered User InfamousDX's Avatar
    Jan 2003
    Bergen, NJ
    Perfectly said by Lance. To combat this, I just do about the same and pop it in 4th and then R. ALWAYS works on the first try.
    Registered User is2scooby's Avatar
    Jun 2002
    Honolulu, HI
    It's unfortunately "par for the course" with our fine automobiles.
    Aloha, Richard...
    Retired Moderator
    TXS Stage 4 UTEC + TMIC + JoeP
    12.75 @ 105.67mph - 1.74 60'
    Dec 2002
    Calgary, Alberta
    I dont think there is a std out there that does not do the same thing. Some are worse then others. I have owned two Mustangs, camaro, prelude, RX7, a couple of celicas that were all standard and they all did it more or less.
    Registered User SubieGalRacing's Avatar
    WA
    all my subaru's do this...
    hell.. on my 360... NONE of the gears are synch'd...
    double clutch and you'll have no worries...
    jamie
