Tools needed to Mod you Car.
Page 1 of 3 123 LastLast
Results 1 to 15 of 40
This is a discussion on Tools needed to Mod you Car. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Lets Start a discussion to list the most usefull tools that all you guys use to work on the car. ...
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    All the Needed Tools..
    O2 sockets,Wrenches,ratchets ,screwdrivers.
    everything.
    lets just start listing it.
    Thanks
    Tuca
    2002 Black Wagon WRX
    315HP With the PM-ID
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    I'll add;
    Good metric socket set and box wrenches
    Flex head rachet
    Universal joint
    Breaker bar
    Floor Jack
    Jackstands
    Head lamp (this is so usefull)
    Beer
    The list could go on and on but these are some of the basics I use.
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    something to cover the fenders while you lean on it....
    Aug 2002
    Brazil
    Jrod,,what is a breaker bar?and box wrenches??
    I will add to that some nice extensions to put in the ratchet.
    O2 socket,(is there a proper socket for EGT sensor??),Ahhh,,and a torque wrench too..
    Tuca
    Registered User NJwrbT-WRX's Avatar
    Apr 2002
    One Square Mile, NJ
    A good oil filter removal tool. There are many on the market, but one is definately necessary. Also, some sort of extener tool with a gripper on the end of it for when you drop stuff into your engine bay and cannot get your hand in there to pick it out. I will post more when I think of it.
    -joe
    '02 WRB Sedan
    Removed silencer w/ Akimoto Velocity Stack, Blitz Dual TT, Autospeed Prototype Up-pipe w/ Flex-joint, Autospeed Crank Pulley, Autospeed OEM Dead Pedal, Samco IC Hoses, Axxis Pads, Goodridge Lines, Neo Synth Brake Fluid, Speedbleeders, Eibach Pro-Kit, Perrin Endlinks and Rear Sway, 17" Sub Zeros w/ 225/45 ES100s, Crucial Racing Thermostat and 1.4bar Radiator Cap, Autometer Sport-Comp Oil Pressure, EGT, and Voltmeter on the A-Pillar, STI Hoodscoop.
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Tuca
    Box Wrench
    Breaker Bar
    Some call them flex handles. They are used when bolts/nuts are too tight, that you can't use your regular ratchet. A breaker bar is much longer, you apply more torque onto the bolt...basically better leverage..
    Some flare nut wrenches (brake lines, etc.)
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    -joe
    Get yourself a big pair of channel-locks. They work well for the oil filter, plus they have a hundred other uses.
    Personally I'd get combo wrenches rather than box on both ends - box on one end, open on the other. Two sets is handy for getting onto both the nut and bolt- I have three actually - standard Craftsman combo wrenches, short combos (for those tight spaces) and a long set that is box on one end and "quickwrench" ratcheting (sorta) opens on the other. Then I have a set of ratcheting box wrenches........I gues what I'm trying to say is that you can't have too many wrenches!
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    tan
    tan is offline
    Dec 2001
    Wharton, NJ
    Sometimes check out the clearance tables at Sears. Last year I got a sweet metric combo wrench set (I think 24 pieces) for $20 when its MSRP at $70.
    Aug 2002
    Brazil
    Thats what i will look for.
    Tuca
    Apr 2002
    One Square Mile, NJ
    They have Sears in Brazil, WOW!!!
    Another to add to the list, needle nose pliers in a few sizes, I always seem to need them regardless of what I am doing.
    -joe
    '02 WRB Sedan
    Aug 2002
    Brazil
    -joe
    No in Brazil we have Walmart,Not Sears.
    But i will use my computer to buy from Sears
    And needle nose pliers i think you mean pliers with very thin nose,,appearing to be 2 needles at the end of the plier.
    am i correct??
    thanks
    tuca
    Moderator
    Apr 2002
    Greenville, SC
    Yes, needlenose pliers are pliers with very small tips, though not actually as small as needles.
    To the list, I'd like to add:
    - normal pliers
    - heavy gauge extension cord
    - multimeter
    - soldering iron
    - wire crimper/stripper
    - several good worklights
    - dremel tool
    - Rhino Ramps
    - Torque wrenches (in both in/lb and ft/lb scales)
    Used a little less often but still awfly handy is:
    - rubber hammer
    - ballpeen hammer
    - bench vise
    - bench grinder
    - hacksaw
    - visegrips
    - air compressor
    - impact wrench for air compressor
    - a big fan and a space heater to keep your garage at a bearable temperature
    2002 WRX Sedan - 2000 Mazda Miata
    Do us all a favor: work on learning how to drive your car before adding more power. Pretty please.
    Moderator beastcivic's Avatar
    Mar 2002
    Charlotte, NC (USA)
    - rubber hammer
    I prefer 'dead blow' hammers. They have steel shot in them (or something like that) which deaden the 'recoil' of a rubber mallet. Saves you from accidentally banging it into something else once it bounces off whatever you're trying to hit with it.
    -Jim
    '02 Platinum Silver WRX sedan w/roof rack...bone stock. Ok, now that's a lie.
    GO HOKIES!!!!!!!!!
    Jul 2001
    Plains of Eastern Montana
    The nice thing about Subaru (vs my damn Chevy metric AND SAE truck ) is that you only need a few select sizes- 10,12,14,17,19,21,22,30- this greatly pars down your tool needs.
    I'm like GV27- can't have enough wrenches and I find I use most of them. One thing to pay attention to is 6 point vs 12 point. When you get into the bigger stuff, I'd highly recommend 6 point- less chance of rounding off a nut or bolt.
    I also find having a wide assortment of extensions, universals and wobble sockets can make a seemingly impossible job possible. A torque wrench, while expensive, is somewhat of a necessity IMO- I use both a 3/8 and 1/2 one on almost every project.
    Another nice tool is the ratcheting comination wrench, this lets you get into tight spaces (like a combination wrench) but also offers ratcheting action- saving you mucho time in many applications. Unfortunately my tool choice- Craftsman, offers a metric set but includes a bunch of sizes I don't need, but worse no 17mm- which you'll find is a very go to size w/ the Suby.
    Big Sky
    Jul 2001
    Joy O Joy! Just went to sears,com and found out they do make a 17mm ratcheting wrench, it's just not in their metric "set"- 10,11,12,13,14,15,18- don't need 11,13,15 or 18.
    This is what they loook like:
    I just ordered individually 10,12,14,17 and w/ my craftsman club tool discount and free shipping rebate got them for $75.
    Stoked (tool fetish )
    Big Sky
