A Couple Timing belt Questions
Results 1 to 5 of 5
This is a discussion on A Couple Timing belt Questions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I was told that Subarus use chains instead of timing belts but then I just heard that only the 6 ...
    May 2007
    I was told that Subarus use chains instead of timing belts but then I just heard that only the 6 cylinders use chains.
    I have an 02 wrx and don't know if it has a timing belt or chain and wouldn't know what to look for. What do 2002 WRXs use?
    Also, if I have a timing belt, at what mileage is it recommended to change it? My car has 86,000.
    Thank you
    Registered User 06grayrex's Avatar
    Mar 2006
    STL
    It has a belt. I believe the manual says around 105k...
    Hawk-Eye Alliance #666
    Stage 2
    May 2007
    Thank you.
    Also, does the 02 wrx have the feature where your engine cuts out (or something to that effect) if the timing belt breaks so that your engine won't be destroyed?
    Jun 2007
    eprov rhode island
    Quote Originally Posted by JonnyWRX View Post
    Thank you.
    105 is what the maximum is..most including me would recomend at 80k and if your belt breaks prepare to do a valve job and possiblly more...id have the bely replaced now to save yourself headaches/costly repairs..also its not a simple timing belt id suggest having a dealer do it...
    New England F4
    feel free to pm me with any questions..
    May 2007
    Thanks for the help.
