~~Help Needed~~ No Fuel while driving~~ - Page 2
Results 16 to 30 of 37
This is a discussion on ~~Help Needed~~ No Fuel while driving~~ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey if you want you can im my aim name areudown420...
    Jun 2007
    eprov rhode island
    New England F4
    feel free to pm me with any questions..
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    if the relay isnt installed nothing should happen to the fuse, it will only blow if there is a short to ground of the power side of a circuit before the load. in this case since the relay is gone the circuit ends there so between the fuse and relay harness is the short.
    if the contacts in the relay short that could cause the fuse to blow, but this isn't your case as it still happens without the relay installed.
    the way the turbo timer was installed could cause the problem as maybe the connectors corroded or started rubbing against something. visually check as much of the wiring you've added as possible.
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Registered User subieracer18's Avatar
    Oct 2004
    Savannah, GA
    no, no multimeter. Looks like i need to buy one. I tried to edit the photo with paint lol. so you guys are saying that the short could be in here somewhere?
    VF-39 Powered
    298.71HP/282.36TQ on 93Oct
    319.32HP/308.27TQ on 110Oct
  6. #19
    Oct 2004
    Savannah, GA
    Also, what does the number 4 go to on the top right corner?
    VF-39 Powered
  7. #20
    Jul 2007
    Thats not the clutch switch is it?
  8. #21
    Dec 2005
    San Jose, CA
    #4 goes to the OBDII diagnostic link connector, so you're right, somewhere along that red line there is a ground where there shouldn't be
    try pulling out the main relay as well as the fuel pump relay, that big fuse 5 feeds the main relay so wiring on that circuit could be grounded too...
  9. #22
    Oct 2004
    Savannah, GA
    so, if i pull the main relay and the fuse still blows, what does that mean? If the fuse doesn't blow anymore what does that mean? I'm kind of a noob when it comes to electrical stuff.
    VF-39 Powered
  10. #23
    Dec 2005
    San Jose, CA
    if you pull the main relay and the fuse stops blowing, then the short to ground is after the main relay, if it does not stop blowing then the short is before both relays
  11. #24
    Oct 2004
    Savannah, GA
    wow.. i have no idea where to start!! i pulled the main relay and it still blew. so that means in my should check where i highlighted the picture.
    VF-39 Powered
  12. #25
    Dec 2005
    San Jose, CA
    you got it... i'd start by removing as much of the dash and front trim as easily possible and following the wires, it's gotta be there somewhere...
  13. #26
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Subscribed...
    This stuff really interests me because I have no knowledge of subaru's wiring. I wish you the best of luck man.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  14. #27
    Oct 2004
    Savannah, GA
    well, i'll probably start attacking the dash tomorrow in hopes of finding this wire. Do you possible know what the color of the wire is that goes from the Fuse box under the hood to the fuel pump harness?
    VF-39 Powered
  15. #28
    Oct 2004
    Savannah, GA
    also, how do i check the relay with a multimeter?
    VF-39 Powered
  16. #29
    Oct 2004
    Savannah, GA
    **Update**
    Ok, so i took half of my dash apart yesterday and overlooked alot of wires. I didn't see anything out of the norm. No loose wires, or open wires touching metal or anything. Something did change though. I pulled the main relay and then put a new fuse in the #5 spot and the fuse did not blow. Could the front 02 sensor cause this? I remember when i installed the uppipe that the wires were kinda exposed, so i put electrical tape around each individual wire to make sure they didnt touch eachother.
    VF-39 Powered
  17. #30
    Dec 2005
    San Jose, CA
    the front O2 sensor is on the circuit for SBF-5, it's after the main relay so for the O2 sensor to blow the fuse the main relay would have to be installed. With both relays out of the circuit it is open at each relay. Did you put the relays back?
