06'WRX multiple cylinder misfire at 3750 RPM
Page 1 of 4 1234 LastLast
Results 1 to 15 of 49
This is a discussion on 06'WRX multiple cylinder misfire at 3750 RPM within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Any smart ones out there? Have a 2006 WRX that pulls cylinder misfire for 1,2,3 and 4 but ONLY when ...
    Jul 2007
    Question 06'WRX multiple cylinder misfire at 3750 RPM
    Any smart ones out there? Have a 2006 WRX that pulls cylinder misfire for 1,2,3 and 4 but ONLY when the tach reaches around 3750 RPM. Regardless of which gear you are in. You can reach 3600 and back off without pulling a CEL. If you try to work through it the tach flutters at 3750 and higher. A CEL will flash and then go out. If you continue driving at those RPM the light will continue to flash and EVENTUALLY set and the "cruise" light will then flash until you clear the ECU.
    The process will repeat again at 3750 RPM.
    Yes, this will happen if you rev to 3750 standing still.
    In addition, the tach will misfire (flutter) at any RPM over 3750.
    Checked: timing marks, changed crank sensor, changed plugs, swapped coil packs, and yes 3 full tanks of premium gas. Only swap was someone put a 2004 down pipe and cats. Up pipe is stock as well as the turbo.
    ** No other codes except an occasional "Emissions pressure sensor voltage high**
    Any help would be appreciated!!
    Registered User kiger0183's Avatar
    Oct 2005
    SLC, Ut
    sounds like a spark plug issue. What mods do you have? Upgraded turbo? Miles? Give us some details..
    Stage II and loving it!
    Jul 2007
    5600 miles. New plugs already installed.
    Jun 2007
    eprov rhode island
    i believe there is a reprograming for that issue...im looking for it so i can be sure..but i am almost certain i remember reprograming a rex for the same issue..if i find a tsb or a reprograming code ill post it here for you...
    New England F4
    feel free to pm me with any questions..
    Oct 2005
    Late Devonian
    Could it be a clogged fuel filter or crapped out pump?
    Jul 2007
    I am not sure. It truly is frustrating.
    I will pay the one with the ability to solve this issue.
    In addition: rechecked timing marks.
    It just goes on a miss rampage at 3750 rpm and higher.
    Need a SMART TECH!
    Best regards.
    Jul 2007
    Quote Originally Posted by subarutech View Post
    Jul 2007
    I will take all advice here!
    Jul 2007
    Still No Help Out There???
    Administrator
    May 2003
    Any mods?
    GraysonSubaru's Avatar
    May 2005
    Knoxville, TN
    Quote Originally Posted by Trainrex View Post
    Any mods?
    +1
    Hey, being the forum car ADD guy is better than being the forum OG.
    Well nobody cares what you think, Seth
    Registered User SubyPsycho's Avatar
    PA
    Looks like the op posted this question twice. I just replied to the other thread, but I'll say basically the same thing here:
    It sounds like your engine is going into limp mode. The tach fluttering/loss of power above 3750 rpm definitely sounds like limp mode to me. I think that's a reaction to the underlying problem, not an indication of the cause.
    Pull all of the CEL codes you're getting. Also, do you have a way to read boost? If you can read that, it would give another indication of whether it is in limp mode.
    Jul 2007
    Question
    Misfires 1,2,3,4
    Emissions control system pressure sensor (high)
    Occasionally after driving, turning off and restarting...
    there is a 5 second cranking period before it fires. Not all the time however..
    Help
    Jul 2007
    No boost gauge to measure boost at this time..
    Between the dealer saying " NEW ENGINE" to others without a clue... it truly is frustrating...
    Jul 2007
    Lightbulb
    $100 to the one who can solve this mystery.....
