06'WRX multiple cylinder misfire at 3750 RPM - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
This is a discussion on 06'WRX multiple cylinder misfire at 3750 RPM within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Was it a salvage car? If so it wasnt a Katrina fixer upper was it? I'd personally spend 80 bucks ...
  1. #31
    Moderator
    Jul 2003
    Maryland
    I'd personally spend 80 bucks and get a tactrix cable and flash the ECU with a stock 06 map. I'm sure there are several of them wondering around.
    If it's a flood car it could be just about anything.
    Have you checked the coils?
  3. #32
    Jul 2007
    All connections are good. Spent $800 at the dealer and they said to pull the heads!! WHAT?
    Compression is good... WHY?
  4. #33
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by lola123 View Post
    HOW ABOUT THE STOCK MAP.
  5. #34
    Jul 2007
    Quote Originally Posted by 302@12psi View Post
    No, not a flood car.
    Also, the dealer said it was not a MAPPING issue.
    Who can you believe anymore........
  6. #35
    Jul 2007
    MAF sensor in after the airbox has been swapped out twice..
  7. #36
    Jul 2007
    AWARD TO WHO CAN SOLVE THIS ISSUE!!
  8. #37
    Jul 2007
    WILL STILL MISFIRE EVEN IF YOU BYPASS THE TURBO..
  9. #38
    Moderator
    Jul 2003
    Maryland
    How do they know it's not a mapping issue? AFAIK Subaru cant tell at the dealership if the car has been reflashed or not. For instance the car might have Cobb's stage 2 map on it. They would have no way of verifying what map is on the car.
    I assume they could have flashed a stock map onto the car but do you know for sure they did this?
  10. #39
    Jul 2007
    They said the ECU was fine. They pulled it and cross checked the numbers with the Subaru TECH line..
  11. #40
    Jul 2007
    I am not sure if they flashed it. However, I am pretty sure they did didn't. They said this was NOT the problem.
    PULL THE HEADS AGAIN is all they gave me..
  12. #41
    Registered User 06PearlWRX's Avatar
    Dec 2006
    SoCal
    just because its the correct physical ecu unit doesn't mean its fine. i'd say the first step is to have them just reflash your stock map. that way you can completely rule out that its running the wrong map.
    "90 miles an hour through trees sideways is pretty damn scary" ~Ken Block
  13. #42
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by 06PearlWRX View Post
    Get a tactrix cable for 80 bucks. Reflash a stock map to your vehicle. See if that fixes the problem.
    Being the proper ECU means nothing. You can rewrite it. AFAIK the dealership cant check to see if the car is running a SOA map or a aftermarket variant.
    You have a 04 DP on the car. So odds are likely the car has/had some kind of stage 2 map on it.
  14. #43
    P0453
    That's an evap vent code. The vent resides in the back of the car in the gas tank. I don't think that's a show-stopper code though.
    I see nothing to be learned by pulling the heads.
    I don't see why to believe the dealer.
    Very worthwhile IMO.
    Les jeux sont faits.
  15. #44
    Jun 2007
    eprov rhode island
    check next to the alternator..right side..should be a regulator/seloniod..couple of hoses..one could be off..causing your code
    New England F4
    feel free to pm me with any questions..
  16. #45
    Moderator
    Jul 2003
    Maryland
    If that fixes it I'll split my 100 bucks with SD_GR
