Oil in the Intercooler
Results 1 to 5 of 5
This is a discussion on Oil in the Intercooler within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 04 WRX with 60K miles. I just removed the stock intercooler and put a bug one on. ...
    Jul 2007
    I have a 04 WRX with 60K miles. I just removed the stock intercooler and put a bug one on. I noticed some oil in the cooler. Not enough to pour out but still very noticible. I use about a quart of oil every 2000 miles. Should I be worried?
    Jul 2004
    Seattle, WA
    Having a little bit of oil in the intercooler is normal, because there is a hose that connects from the crank case to the intake.
    Getting a Catch can is a good idea. Here is a catch can FAQ
    Using a quart of oil every 2000 miles is a problem. Is it burning the oil or leaking?
    Jul 2007
    Quote Originally Posted by jeremy96gase View Post
    Not leaking. No smoke. Threw a rod at 45K and the dealer broke it down and fixed it under warranty. I noticed the oil use after that.
    Jul 2004
    Seattle, WA
    You should ask your dealer to look at it again, especially if it’s still under warranty.
    Using a quart of oil every 2000 miles, is bad. It's got to go somewhere. If it's not leaking on to your driveway, then it's probably burning the oil.
    Quote Originally Posted by tpan View Post
    Why did you throw a rod at such low mileage?
    I agree. Make sure the PCV is connected correctly and see that there are no leaks onto the exhaust or turbo -- these could be hard to see as drips since the oil would just burn off.
    Although roughly five times (5X) the maximum oil use I've ever seen from my motor in five years, it is still considered "acceptable" as absurd as that may sound. I'd still recommend complaining about it firmly until someone figures out what's going on.
