A/C woes, what else is new
Results 1 to 7 of 7
This is a discussion on A/C woes, what else is new within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Not quite sure what's going on with my A/C. That whole feature of my vehicle has always been a gray ...
    Dec 2006
    Not quite sure what's going on with my A/C. That whole feature of my vehicle has always been a gray area for me.
    Anyway, it doesn't work. Compressor doesn't kick over. It still spins freely if I spin it manually, there isn't a lot of resistance or anything, but it doesn't work/pump. If I hit the AC button, the light still comes on, fans still work, but the compressor doesn't come on and there's no noticeable change in idle or 'strain' on the engine as would usually happen.
    I really don't know if this could be electrical or have to do with belt tension or if it could be refrigerant levels or what. Like I said, a little clueless with AC.
    It stopped working basically when the guide/tensioner pulley took a **** on me. My belt ate all the way through the plastic on the old pulley, so I replaced my belts and got a new tensioner pulley. While I didn't know what had been going on with it until a little while later, I knew something was wrong because my ac obviously wasn't working. This leads me to believe that my refrigerant level is probably fine. To me, it doesn't seem like a pulley going out and the belt losing tension would affect the plumbing. But, I could be wrong as I don't know a lot about this stuff.
    Having watched one of the periodic reviews on nasioc, they had a section on the ac and it clearly showed that when you hit the ac button, the compressor starts going. Mine doesn't do that, obviously. So I'm not sure where to start or what to do.
    I guess any suggestions would be great. Thanks.
    Jun 2007
    Great Salt City of Utah
    The clutch
    Dec 2006
    Interesting. never really thought about it. I guess that would make sense if the belt destroyed it. The tensioner pulley had somehow been in one spot, as the belt was being drug across it and wore it down to the bearing housing.
    Jun 2007
    I need to loosen my tensioner alittle. I figure A/C is on of those things you sacrifice when go stage 2. The load on the engine is insane. Makes my car run like ass.
    Dec 2006
    Well I just went out and "spun it" with the engine off. There's some resistance, but it's intermittent. Kinda like it has kinda "spots" where it's hard, then you push some more and it goes into spinning kinda easily and then back to a tough spot, with not a lot of distance in between the two.
    Dec 2006
    And if I didn't say "kinda" enough in that last post, here's another kinda.
    Dec 2006
    Well the clutch kicks on. Just needed more tension. I can't tell if it's blowing cold or not though. I live on the coast and the air coming in is already cool. If I use the recirc it doesn't get any colder. So I doubt it's cooling the air.
