help bad sounds
Results 1 to 11 of 11
This is a discussion on help bad sounds within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My car started making lots of noise and lost boost. I pulled the code from the CEL and it was ...
    Mar 2007
    idaho
    help bad sounds
    My car started making lots of noise and lost boost. I pulled the code from the CEL and it was PO340. Has anyone had this problem before.
    Shawn
    Registered User DentGuy05's Avatar
    Jul 2007
    Algonquin IL
    that is a cam sensor code, it would explain the all the other problems to. you most likely have a bad cam sensor. good luck
    Mar 2007
    idaho
    So what is the sound of a piston slapping around in my block. Someone told me it could be the cam sensor slapping around but i lost boost along with power. there is no water mixed in my oil so i know its not a head gasket.
    Jun 2007
    eprov rhode island
    Quote Originally Posted by shawnc View Post
    cam sensors bad...the cam sensor uses the cam gear as a refrence for timing..your most likely hearing your can pinging from inpropper timing control.....hence the loss of power....also check with your dealer i believe there may be a reprograming for that code...if so do the reprograming and the sensor..otherwise youll be eatting sensors on the reg..
    New England F4
    feel free to pm me with any questions..
    Mar 2007
    idaho
    so this sensor is in my head some where. sorry for all the dumb question never worked on a boxer engine before.
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    cam sensor is located in the top front of the driver's side cylinder head on my 05 WRX, so it's probably similar to other EJ20x series engines. the STi block (EJ25x) has two cam sensors, one in the top rear of each cylinder head. year and model will help...
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Mar 2007
    idaho
    i have a 03 wagon.
    Dec 2005
    San Jose, CA
    then it's definitely in the driver's side cylinder head on the top, it's near the battery
    Mar 2007
    idaho
    Cool I changed out the sensor and i am still making alot of noise. Does it need to be retimed.
    Jun 2007
    eprov rhode island
    scroll down and read everything i wrote about changing the cam sensor...also there is a possibility which is not likely... your cam gear could has defects in it.. its doubtfull but possible..could also be a wiring issue.. but ya go read what i said before...
    New England F4
    Mar 2007
    idaho
    Well i did what i thought i did i blew the crap out of engine. chunks of piston in my oil pan.
