Engine Misfire
Results 1 to 10 of 10
This is a discussion on Engine Misfire within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I am having a misfire in Cylinder 1, 3 & 4 The dealer cannot figure out what is causing the ...
    Jul 2007
    Engine Misfire
    I am having a misfire in Cylinder 1, 3 & 4 The dealer cannot figure out what is causing the problem. The dealer has updated CPU. Now they think I need a new engine. Does anyone have any other ideas?
    2003 Subaru WRX 110K miles
    Stock (no mods)
    Registered User LeeC's Avatar
    Oct 2005
    Baltimore MD
    EDIT: You added in no mods while I was posting... Check the plugs and coilpacks, when do you get misfires, at idle? normal driving? Flooring it?
    For alot of people misfires are so common and can be caused by a few different things, that most people just ignore them. Unless they are warrantying a new engine for you, don't listen to that. Here are a few things that can cause it.
    Spark Plugs, Coilpacks you mentioned nothing about cylinder 2, switch cylinder 2's coilpack out with say cylinder 1, see what happens, however I doubt all 3 coilpacks went up at 1 time. Light pulley (rare but it can happen), an oversize fuel leak(often throw with an evap code), Light Flywheel, Bigger injectors, injectors installed incorrectly(o-rings, etc.)
    Good luck with finding your misfire.
    Lee
    94 Anthracite 6spd Supra - 9.87@147
    LS2 RX7-2014 Tundra DC-GD Race Car In Progress
    Jul 2007
    There are no Mods. Fully Stock car. I checked the codes before I took it to the dealer and I saw cylnder 1 & 3 were missing. They say 1, 3 & 4 are missing. The Car has had regular scheduled services (including a new timming belt around 105K).
    Miss only happens at low RPMs (below 3000)
    Oct 2005
    Baltimore MD
    Do you know how to change spark plugs on these cars??
    Oct 2005
    Baltimore MD
    Out of curiosity what dealer are we talking about??
    And have you ever had any work done with your fuel system by them such as replacing injectors?
    Jul 2007
    The Dealer is Roseville Mazda-Subaru. In CA
    No work done on the injectors. Only scheduled maintenances ( Oil changes tune ups)
    I have never changed the plugs on this car. But I assume it is like changing the plugs on any car.
    Oct 2005
    Baltimore MD
    It is the same as every other car just slightly more difficult to get to. Checking your plugs would be the first think you should do.
    Lee
    Jul 2007
    I just spoke with the dealer's service tech. He did check the plugs, they are fine. He describes the problem as an engine surge not a missfire. They did a valve adjustment and verified the timing belt is correct. The leak down test shows a issue in cylinder 1, 2 & 3 (not 4). They are now trying a compression test.
    I still think it is an electronics problem (loose connection or bad computer) or a fuel injection problem.
    Apr 2007
    North carolina
    one of my friends is a tech up here and he told me that pretty much he had one like that come in and that he reflashed the ecu. subaru is suppose to have reflashes is what he told me.. But the only reflashes they have are for misfires. mention something to them about the misfire reflashes or somethign to that effect.
    Jun 2007
    eprov rhode island
    Quote Originally Posted by bfreeman View Post
    if cyl # 2 has no problem switch the injector from to with with another 1 or 3..see if the codes change..injectors are a known problem with these vehicles... be carefull though when you switch the injectors make sure you install them the same EXACT way they came out..there is a specific spray pattern..installed improperlly may cause a lean or rich running condition...
    New England F4
    feel free to pm me with any questions..
