Yes, there could be a pinched vent line. I've found "hard to fill" issues are usually caused by problems in the evap system.
This is a discussion on Any ideas what could cause this ? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have an 06 STi. Last fall I had a lot of upgrades done including a Walbro fuel pump. Ever ...
I have an 06 STi. Last fall I had a lot of upgrades done including a Walbro fuel pump. Ever since then I've noticed it takes fuel VERY slowly. It doesn't matter where or what pump, I have to barely crack the lever to keep it from cutting off. It's also noticeably worse the hotter the weather.
Could there be a pinched vent line ? Have any of you guys ever heard of such a problem ? Help me out if you can. Thanks, Okey
2006 Black Mamba - 20G and lots more !
Dirty Jersey
Part-Time Grammar Nazi
RIP- '02 PSM Wagon
08 Candy White MK5 GTI 6spd
Moderator:Tri-State and Transmission & AWD forums
It is underneath the car usually...it will be a charcoal canister and a few lines. Hard to identify though. Have you contacted the folks who put in the fuel pump and asked them to resolve the issue?
I had an older truck that did this and it drove me up the wall. It was the evap system on this and the solution was to YANK IT OUT!!! But I could do it as it had reached "classic" status.
tEh PriUs=teH faSTah!@@!
306 AWHP/341 AWT, Stage 2
[QUOTE=YBNormal07;1973738]It is underneath the car usually...it will be a charcoal canister and a few lines. Hard to identify though. Have you contacted the folks who put in the fuel pump and asked them to resolve the issue?
The place that did the work is 4 hours away. I would prefer to resolve it myself if I can.
Is there a vent line where the pump assy. goes in the tank that could be pinched ? Or where should I start ? Thanks guys for all the response. On another forum I got 10 responses. 2 were useless flames, and the other 8 were telling me it's the gas pump, not my car !
The only other thing I know of is people have had issues with the little filter on the pump itself. Some people actually use the old filter that was on the original pump because they run into flow issues. I have not had this problem personally, but I did see it in another STi one time, an 05. Just another avenue if the first doesn't pan out. Do you have a stab in or any way to gauge the feul pressure?
Dirty Jersey
RIP- '02 PSM Wagon
There are a number of reasons that can cause a slow fill rate. The vast majority are associated with the evaporative emissions. It will be the vent line from the filler neck, the carbon canister, the outlet vent from the carbon canister, or even the vent valve. You'll have to crawl under the car and start looking. Find any open line and trace it back. This will lead you to the canister eventually. My bet is the vent line is kinked or plugged or the drain valve or filter is blocked. Here is a diagram for those techies interested:
totally an EVAP line having issues... pull up the back seat where the fuel pump is located & check the lines at the pump, its probably something in there
Blobeye Syndicate #75
2005 OBP WRX Sport Wagon
Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
Cobb stg 2 / STi uppipe / Crucial Racing downpipe
Stromung 2.5" catless centerpipe / Scooby Sport New Age centre pipe & backbox
New England F4
feel free to pm me with any questions..
at the bottom of the fill pipe..underneith the car..where the tank hose and filler neck hose meet...just disconect the rubber hose from the metal and you will see a little plastic piece inside the metal filler..the only reason the valve is there is in case you roll over your vehicle the gas cant leak out..its a one way valve set up..hense the name roll over valve![]()
New England F4
