Burned clutch on my 2002 used. (owned for less than 2k miles) - Page 3
Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 67
This is a discussion on Burned clutch on my 2002 used. (owned for less than 2k miles) within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; <---shortly going to stage to <---shortly going to put in STI RA Gears w/a performance clutch total cost for reliable ...
  1. #31
    Registered User fenderwrx's Avatar
    Apr 2007
    Southwestern MA
    total cost for reliable stage 2:
    DP~400
    SPT Intake w/heat shield - 200
    SPT Exhaust: 420
    AP2.0: 695
    STI RA Gears 1500
    Performance Clutch, cover & lightened flywheel: 1000
    Total cost for build:
    4215
    Will tranny blow up if VF22 is installed?
    NOPE! YAY! :P
    Fender + WRX > Fender + VW...
  3. #32
    Registered User LarenF3D5's Avatar
    Jun 2007
    Albany NY
    Quote Originally Posted by fenderwrx View Post
    hahaha - yeah - is it the borla hush or the 3" T-304 stainless?
    It's the Borla hush. I'm told the only real "hush" about it is the look.
    I think the weakest part of my position is I don't want to shove the car up his ass. I'm really happy with the vehicle so far, they just need to make good on what's messed up, and pronto!
    I've got the other shop I go to giving the car a once over. I asked them to just check the whole thing and see what else needs work. Then I'm gunna fax my salesman the printed list of what needs to be done, and tell him to get scheduling my work. And I'd better not be paying for a damn thing. (except upgrades perhaps)
    "You got a HOOD SCOOP?!" -Francis (A co-worker, on seeing my 02 WRX for the first time)
  4. #33
    Administrator
    May 2003
    In this case, who knows.
    A clutch can last 150k, and/or a clutch can be killed in the span of 5 miles. Heck, you could kill a clutch without going 1 mile.
  6. #34
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Quote Originally Posted by Trainrex View Post
    I've seen someone do that before!! inexperienced!
  7. #35
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Quote Originally Posted by LarenF3D5 View Post
    Best approach. Act as though the repairs are a given and just get the work scheduled. This leaves them with the onus of having to explain why they are denying your warranty (if they decide to do so) and puts them on the defensive rather than vice-versa. I hate it when dealers try to make you feel like you have to defend THEIR service contract.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
  8. #36
    Jun 2007
    Great Salt City of Utah
    I wouldn't even mention upgrades at all
    And if the clutch is not compleatly out I think you will be hard pressed trying to get him to replace it.
  9. #37
    Jun 2007
    Albany NY
    The shop just called me, they told me there was a "list" and wouldn't get into it over the phone.. I'm gunna call them back after my first break and push the issue.
    Now I'm concerned.
    Edit: I called them back, they told me the front rotors and clutch need to be replaced. They said it "should" all be covered under warranty.
  10. #38
    Apr 2007
    Southwestern MA
    nice. now just push for a mechanical failure clause and get some money back or something like it hahaha
  11. #39
    Jun 2007
    Albany NY
    Yeah, here's to hoping they make good on it.
  12. #40
    Jun 2007
    Albany NY
    Bumpdate
    Just got home after picking the car up from the shop (Monro in Albany). The printup they gave me of "Work to be done" is as follows;
    Brakes
    $134.67(cost) + $25.50(labor) = $160.17 RF Brake Rotor
    $134.67(cost) + $25.50(labor) = $160.17 LF Brake Rotor
    Service
    Clutch is slipping--Requires clutch assembly and flywheel replacement.
    There's no estimate for the clutch work because the shop doesn't do clutches this time of year, I guess.
    They suggest I get a second opinion from AAMCO in Albany, I guess they do a lot of transmission work. Given their writeup with the whole thing needing replacement (I mentioned the throw out bearing and the mechanic said it was included in the term "Clutch assembly") and including the flywheel if the dealer follows it and finds the same issues (I'm getting a second opinion to throw in their face in case they decide not to) I should be set pretty well.
    Since the mechanic says the whole thing needs to get done (including the flywheel) I may be able to upgrade the whole setup a little cheaper still (here's to hoping).
    Just thought I'd update the situation. I know it's kept me on the edge of my seat all day.
  13. #41
    Jun 2007
    Albany NY
    Hey, I hate to beat a dead horse but I've got another question on the matter, and figured I'll try to put it here before throwing it in a new thread.
    I took my car to AAMCO (a transmission shop) to get looked at today. The mechanic there said that the apparent over-rev of the tach was due to my car being a turbo, not the clutch slipping. He said the clutch was on the way out, but not slipping as of now.
    Is it regular for a WRX or turbo in general to tach way up before accelerating strongly? Is it possible that a mechanic that was unaware of the car being a turbo (which I find hard to beleive) could mistake the turbo itself for a slipping clutch?
    I'm still pretty new to MT, though my driving has gotten very smooth. I'm just trying to find out where I stand before yelling at my dealer to tear apart the transmission and being charged $600.00 in labor to find out nothing was "wrong" enough to justify it.
    -Thanks
  14. #42
    Apr 2007
    Southwestern MA
    -Thanks
    yeah, it revs way up but you shouldnt gas it hard in 1st anyway -t he 02 has a fairly weak tranny. but yeah, the clutch is gonna be starting to slip, and the brakes have prolly not been replaced in 40000 miles.
    i would have them do everything, if you were in first and the clutch was past the catch point and revving up, then somethings wrong. it sounds like the clutch is def. on its way out.
  15. #43
    Jun 2007
    Albany NY
    I never did gas it hard in first, that's something the first mechanic said signaled that the clutch was an issue. Both mechanics stated that the clutch needs replacing soon no matter what, like I said 74,400 miles on it, no clutch/transmission work.
    All of the breaks have been replaces in the last 15000 miles, they replaced the rear brake rotors 12000 miles ago. But for some reason they haven't touched the front rotors (which will change Monday).
    I definately want them to do everything, and get my vehicle in tip top shape, but I'm afraid of eating a huge diagnostics cost before they even get to work on the clutch/transmission. I mean, if it's "going" to go or "starting" to slip are they under obligation to fix it? Would preventative maintanence be under warranty (to a point)? I could easily see them telling me that it's not an immediate issue, and to get it done now would cost some serious $$$.
  16. #44
    Apr 2007
    Southwestern MA
    threaten with lawyers and the fact that it will not pass safety inspection next time around.
    whats a good lawyer in the capital district? throw his name out there.
  17. #45
    Jun 2007
    Albany NY
    Hah, I've got no idea. I try to stay out of situations where you need one. But I'll look around.
